Are 4.10's A mistake??? - Mustang Evolution
Old 07-10-2008, 02:41 PM   #1
67mustang97's Avatar
Region: Vermont
I recently purchased 4.10's for my 97 Mustang 3.8/5spd. I'm not sure if I made a mistake? My very short mods list include a Mac fender mount cold air intake, BBK throttle body, 01 GT dual exhaust with custom x pipe and Mac underdrive pulleys. After reading people's posts they say they only get a top speed of about 72 mph. I've also read that if I tune the car I'll only get about 85 mph out of it, is this true? Will I be able to correct my speedo with a tune or a cable? Any in site would greatly be appreciated!!!
Old 07-10-2008, 03:03 PM   #2
jimmy_beaner's Avatar
Region: Iowa
Re: Are 4.10's A mistake???
well, the reason their top speed is so low is because they didn't retune the car. If you retune it, especially with 4.10's, you should be able to wrap 5th out to redline. I highly doubt you wouldn't be able to break 100 in that situation. However, you won't NEED to break 100 mph... You can use a speed cal (I think?) to recalibrate the speedo, or you can get a tuner and it'll do it for you, and remove the speed limiter
Old 07-10-2008, 03:42 PM   #3
RyansQuick6's Avatar
4.10 are too short for a 5-speed, I had them for a while and 1st gear was just for show, i always had to pull away form red lights and stop signs in 2nd so it would spin. I'd say 3.55's for all aorund use or 3.73's for drag racing on fridays.
RyansQuick6 is offline   Reply With Quote
Old 07-10-2008, 04:17 PM   #4
Send a message via AIM to VCS_SSSTANG
I've driven a procharged 5 speed with 4.10s... they seem great if you can handle it. " don't fear the gear "
VCS_SSSTANG is offline   Reply With Quote
Old 07-10-2008, 05:34 PM   #5
yeah their fun, but that's it, you just spin all over and will hate driving down the highway at 2500rpm at 70mph.
Old 07-10-2008, 06:08 PM   #6
Pfft, this thing was on bfg 315s ...
Old 07-10-2008, 06:30 PM   #7
you must get a tune to fix the speedo issue, no way around it, its rpm limited if I remember right not mph, if you cant afford the 2-3 mph you will lose on the interstate then do a diff gear like a 3.73 (not much better)
Old 07-10-2008, 06:32 PM   #8
Region: Vermont
I guess I'll live and learn. The reason I went with 4.10's is because I just blew up my slightly modded 02' GT due to a bad factory oil pump, I wanted to feel a little snap from light to light with my old 3.8. I also wouldn't mind taking down a few Civics on the way lol...
Old 07-10-2008, 09:52 PM   #9
on a 97 I don't think you need a tune, I think you just put in the correct speedo gear and that's it.
Old 07-11-2008, 06:51 AM   #10
4:10s are not too short.. we put 4.10s in 500hp cobras all day and can leave in 1st gear fine.i wont run anything other than 4.10s on a car under 450rwhp. i think 97 takes a programmer to calibrate it.and interstate top speed is barely affected(2-3mph as stated earlier)
SimplyOrange is offline   Reply With Quote
Old 07-11-2008, 07:07 AM   #11
the only reason i would say 4.10s are to short is the 3.8L he has peaks REALLY early in the rpm band so he will run out of rpm about 2,200 faster than a 6k redline peak car would~
a speedo gear is the only way to fix the speedo (and it wont be perfect so you will have a speedo that reads to fast) but the chip is needed to fix the rpm shut off.
I would go with a speedcal to fix the speedo issue if you can use one on your year car.
Old 07-11-2008, 07:12 AM   #12
they have an auto car we just put 4.10s in, i think hes on this board, and it does fine on the interstate,all what you want tho.
Old 07-11-2008, 07:26 AM   #13
I think that 4.10's for an AUTO v6 are fine, but not a stick, I hated mine.
Spector, thank you for proving my point
Old 07-11-2008, 07:29 AM   #14
A cobra and a v6 only share bodies, so the rear gear theory doesn't apply the same. Espescially considering the tranny differences. 6ers also don't have the extra weight of a 6th gear holding them back lol
Old 07-11-2008, 07:38 AM   #15
yea,that 5th gear in the 5 speed helps a little tho over the auto, and the cobra might have a little more weight but twice the torque. personal opinion tho.. i dont care if he runs 2.73 or 5.30s im just letting him know what ive done in the past and gotten away with.
Old 07-11-2008, 09:13 AM   #16
with an 8.8 you can go up to 6.14!!!! I think top speed becomes around 27mph though lol
Old 07-11-2008, 10:02 AM   #17
120mph in the 1/8th lol
Old 07-11-2008, 11:17 AM   #18
but you hit it in the 60', and just cruise the rest of the way! lol
It's probably a PITA always have to do a 5th gear burnout though lol
Old 07-26-2008, 10:24 PM   #19
I had 4.10's on my 02 sixer and it was really too much. my first gear didn't exist i would have to shifgt out of it super fast and usually just left in second because of that. Now that gas is so high i wouldnt reccomend them either, my highway milage went to **** with 4.10's
Old 07-27-2008, 10:52 AM   #20
LilRoush's Avatar
I ran 4.10s in mine and got sick of it. Went back to 3.73 and am going smaller next time I swap rear ends out.
With a car that red lines a touch over 5K, it's a waste. Sure on a 4 cam motor they work awesome with the higher reving motor- but that doesn't matter at all.... you're not driving a Cobra. If it's going for a pure street car, I'd go 3.73.
~Matt
2000 Roush #5004 M112'd V6
1970 Mach 1 351W 5 speed swap
2001 Explorer Sport 4.0L
LilRoush is offline   Reply With Quote
Old 07-27-2008, 11:26 AM   #21
You could always run taller tires - the reason many drag racers run 4.xx - 5.xx gears
4thMustang is offline   Reply With Quote
20 x 10's? Y2E0L0L5OGWT Mustang Wheels & Tires 17 07-31-2007 12:04 PM
8.8 rearend with 4.10's f/s scott8950 Mustang Parts for Sale and Wanted 9 07-18-2005 08:21 PM
V6 gears- 3.73 or 4.10's 99'sleeper Pre-2005 V6 Mustang 19 02-11-2005 08:37 PM
someone with 4.10's thirstymate Pre-2005 V6 Mustang 10 09-10-2004 08:01 PM
3.73 or 4.10's? 98stang Pre-2005 V6 Mustang 28 01-06-2004 09:15 PM
10:16 AM
