Oil - Mustang Evolution
Old 02-05-2013, 05:41 PM   #1
Oil
What is the best oil to put into a 3.8 V6?
Drod24 is offline   Reply With Quote
Old 02-05-2013, 05:47 PM   #2
Royal purple
Blackedout is offline   Reply With Quote
Old 02-05-2013, 06:22 PM   #3
10w30
Old 02-05-2013, 08:42 PM   #4
1slosix's Avatar
RP is overkill...a conventional 5w20 is all the car needs to perform nicely. if you want synthetic go for it but you don't have to spend RP money to get it. Castrol syntec usually runs around $30 with 5 qrts and a filter at most autoparts stores. (the filter is usually a higher end one too like k&n or bosch)
carving corners like a boss
Old 02-05-2013, 09:02 PM   #5
Camo1967Mustang's Avatar
Castrol is awesome, used it in my baby for a long time
and its cheaper at walmart
Adrian
2001 Mustang
--AM CAI, BBK Headers, Dual exhaust, Billet grille, hood and side scoops, Sequential tail lights,
AM Headlight covers, Fog lights, Chin spoiler, H&R Lowering Springs, KYB Shocks and Struts
January 2012 StangAlley ROTM
Camo1967Mustang is offline   Reply With Quote
Old 02-05-2013, 09:32 PM   #6
Justasix98's Avatar
I've always run Castrol GTX in all my vehicles
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 02-06-2013, 01:05 AM   #7
I know royal purple is a high end oil but what is so special about it?
Old 02-06-2013, 01:19 AM   #8
Venomouz831's Avatar
Royal Purpleā€™s advanced additive technologies, such as Synerlec, enable its products to outperform leading synthetic and conventional lubricants. These unique chemistries strengthen the base oil for improved performance. They also create an ionic bond that adheres to metal parts for continuous protection.
)02 Gt, Founder of WE2G
Old 02-06-2013, 09:32 AM   #9
Mustangman92's Avatar
^ This guy sounds like a royal purple salesman haa but what he said is accurate and it is great stuff I used it for my rear diff and 4.10 gear swap... Works amazing but it is pricey
Mustangman92 is offline   Reply With Quote
Old 02-06-2013, 10:23 AM   #10
I use royal purple in everything. Ha ha. Rear end, powersteering, transmission fluid, engine oil, coolant additive, brake fluid, etc. I wish they made a drink called royal purple.
---------- Post added at 12:23 PM ---------- Previous post was at 12:22 PM ----------
Castrals great oil.
---------- Post added at 12:23 PM ---------- Previous post was at 12:23 PM ----------
Racers off fast and the ferious used castrol
Old 02-06-2013, 10:30 AM   #11
Haha idk if the racers off fast and the furious using castrol is a good point ha it could just be for product placement that castrol paid for
Old 02-06-2013, 10:53 AM   #12
Skargon's Avatar
Synthetic oil has a different flow pattern, it may still be 5w-30 or 5w-whatever, but it is still thinner than conventional oil, Therefor on an older car, you may find leaks where there were none before, also your valve train might be a bit louder due to the thinner fluid, their is nothing wrong with using synthetic oil on an older car, it is not going to set it on fire, it's just something you can consider when thinking of changing to Synthetic oil, Most "synthetic" oils are actually a blend, Look for things like Castrol syntec, or Mobil 1 to find full synthetic written on the bottle.
I used to use Castrol High mileage Synthetic Blend, but recently I switched back to my old faithful Pennzoil High Mileage conventional, and my valve train is a bit quieter, and the sound of the engine is a bit smoother, And a pin hole drip I used to have, is not there anymore, So these are all just things to consider.
No performance gain that I can speak of, but some people swear more expensive oil gets them more horsepower.. But if I spent 9$ on a quart of oil, I would want to feel more power as well.
1998 Mustang V6
CAI, Exhaust, Weight Reduction
16.5 1/4 Mile
Skargon is offline   Reply With Quote
Old 02-06-2013, 12:39 PM   #13
Thank you all this stuff really helps out!!! What's th best oil for high performance oil? For a 3.8 V6
Old 02-06-2013, 12:51 PM   #14
1slosix's Avatar
Depends on what you're gonna put the motor through to be honest. Id say just use a decent synthetic and call it a day
Old 02-06-2013, 01:25 PM   #15
I run my motor hard a lot
---------- Post added at 03:25 PM ---------- Previous post was at 03:24 PM ----------
But I've seen how good royal purple was personally
Old 02-06-2013, 01:26 PM   #16
1slosix's Avatar
Lol why's that?
Old 02-06-2013, 01:59 PM   #17
I'm guessing because nothing has ever broken and his performance has been good
Old 02-06-2013, 02:07 PM   #18
1slosix's Avatar
that's not an answer to my question lol
Old 02-06-2013, 02:34 PM   #19
To answer it I guess it's not possible to physically see it haha
Old 02-06-2013, 02:36 PM   #20
1slosix's Avatar
no an answer to why you'd run it hard are things like racing it, a lot of driving...things of that nature lol. take the new 5.0's for instance....ford recommends 5w20 for gas mileage and 5w50 for track use in the same motor
Old 02-06-2013, 02:37 PM   #21
Oh I thought you were referring to the second part of his comment... My fault
Old 02-06-2013, 02:38 PM   #22
1slosix's Avatar
no i just noticed that...it was added after i posted i guess
Old 02-06-2013, 03:55 PM   #23
Xaperez100's Avatar
Castrals great oil.
I'm guessing mr Oconnor didn't use either Since he ****ed up his car in the first race:p but also total purple can last longer than other oils you can have it in your car up to 9,000 miles but I'd still change it regularly
Xaperez100 is offline   Reply With Quote
Old 02-06-2013, 05:58 PM   #24
Well I haul *** quite often but I want to try out a high performance oil
Old 02-06-2013, 07:11 PM   #25
I run my car hard racing it. I use 5w20. When I run i standard shift my automatic, and sometimes on the street I do the same, over reving and redlining I do a lot. And when I took out my lower manifold my drive train was like new, the cam was clean and I've seen others like mine whose motors and drive train was sludged up, and they weren't even as old as mine. I take pride in how I drive, and when I drive I'm one with the car I can sense the tiniest different in timing or air intake and idling. Some will laugh at what I say, but if you don't know your car then you shouldn't be driving it.
---------- Post added at 09:11 PM ---------- Previous post was at 09:10 PM ----------
10w30 was typing fast pizza rolls are cooking
Old 02-06-2013, 07:23 PM   #26
Xaperez100's Avatar
Lmao pizza rolls:p
Old 02-06-2013, 07:25 PM   #27
1slosix's Avatar
lol i'm gonna be honest i did laugh out loud when i read being one with the car. as long as you like what you run go for it any sludge i had left long ago after running a bottle of seafoam in my crank case ;D
Old 02-06-2013, 07:45 PM   #28
wheelman's Avatar
Amsoil here, rated for 25k/1 year. I average 10k/year but I do it at least twice if I track at all, along with DOT4. Awesome stuff. I use it in all of my equipment.
wheelman is offline   Reply With Quote
Old 02-06-2013, 07:48 PM   #29
Doesn't seafoam leave deposits in combustion chamber
Old 02-06-2013, 07:48 PM   #30
1slosix's Avatar
if it does i've never noticed it when anything is apart
Old 02-06-2013, 07:51 PM   #31
Everyone laughs at me. Why sup up that v6? Bc I want to. Later a nice v8 but I'm working on saving my girlfriend that nice Mazda cx 5 she wants. But I have a passion for what i drive and how I drive it.
---------- Post added at 09:51 PM ---------- Previous post was at 09:50 PM ----------
Well that was just a rumor going around this site
Old 02-06-2013, 08:19 PM   #32
1slosix's Avatar
i think that rumor started to a guy that was either banned or ran off last year
Old 02-06-2013, 09:43 PM   #33
Seafoam is fine to use
02:26 PM
