Dome lights red - Mustang Evolution
Old 02-06-2013, 04:00 AM   #1
Mustangdust's Avatar
Dome lights red
Mustangdust is offline   Reply With Quote
Old 02-06-2013, 06:44 AM   #2
V6in's Avatar
That's pretty cool I like the red. Mines a backlight:
V6in is offline   Reply With Quote
Old 02-06-2013, 06:44 AM   #3
V6in's Avatar
*blacklight*
Old 02-06-2013, 07:26 AM   #4
cheelyb09's Avatar
Originally Posted by Mustangdust View Post
Nice, I want some now.where did you get yours.
Old 02-06-2013, 07:27 AM   #5
V6in's Avatar
Well I got mine from superbrightleds.com they have multiple colors. I think it cost $7
Old 02-06-2013, 07:28 AM   #6
cheelyb09's Avatar
Thanks.now to find somebody to install them for me.hehe.
Old 02-06-2013, 07:30 AM   #7
Hmiller's Avatar
Send a message via AIM to Hmiller
Wow I love this idea!
VOTE For MOTM!!!!!!
Hmiller is offline   Reply With Quote
Old 02-06-2013, 07:32 AM   #8
V6in's Avatar
They're super easy. Just get a flat head and remove the lense cover and pull the old out and put the new in. Takes 2 mins if that lol
Old 02-06-2013, 07:40 AM   #9
cheelyb09's Avatar
Kool.I think I want baby blue or pink.
Old 02-06-2013, 10:47 AM   #10
Yea it is easy , next I'm doing red gauges to match my other stuff
Old 02-06-2013, 11:08 AM   #11
Bamman's Avatar
How did you change the color on the knobs? and the shifter.
8 Cylinders Little Brother.
Bamman is offline   Reply With Quote
Old 02-06-2013, 11:08 AM   #12
V6in's Avatar
I'd like to change my gauges. How do u do it?
Old 02-06-2013, 11:53 AM   #13
Mustangman92's Avatar
Use slonisons serafina build the heavy pic one
Mustangman92 is offline   Reply With Quote
Old 02-06-2013, 12:38 PM   #14
SCCofSV's Avatar
Hahaha... I just got some red smd 5050 for my domelight. And going back for two 1-1/4" x 1-1/2"panels. I think those had 12 red smd 5050 for floorboards. Great minds work alike.
SCCofSV is offline   Reply With Quote
Old 02-06-2013, 02:16 PM   #15
Rcary's Avatar
I just got the white ones for the dome and blue LEDs for under the dash
Rcary is offline   Reply With Quote
Old 02-06-2013, 03:58 PM   #16
Xaperez100's Avatar
I've got the red dome also but mines really dim lol
And then I have my gauges red. Took some time but overall it's very easy. I wanna do my ac controls red to but I don't feel like taking everything apart and unhooking my stereo/.-
Xaperez100 is offline   Reply With Quote
Old 02-06-2013, 04:10 PM   #17
Xaperez100's Avatar
Old 02-06-2013, 06:26 PM   #18
How hard was it to do them
Old 02-06-2013, 06:42 PM   #19
Xaperez100's Avatar
Very simple just pull out the cluster. Take off the plastic covering the gauges then be careful when pulling of the actual gauge sheet and needles so you don't break them. And make sure you take a picture of how your gauges were before you do it so you make sure every needle is in the same spot as before. Then when you pull off the gauges sheet be careful because some parts have glue. And then when you get it off then turn it over and scratch off the green film from the numbers. You kinda have to push on it. I used a knife when I scratched it off and I used pressure. And when you put it back on make sure you don't push the needles all the way down either because most of the time they will get stuck. And not move because the gauge sheet will no longer be flat against the cluster. And then put in the whatever color lights you'll be using into the back and plug it all back in and make sure it all works good then close it up
Old 02-06-2013, 06:59 PM   #20
So for the needles , do you have to let car warm up , or just turn to run and take the picture
Old 02-06-2013, 07:29 PM   #21
Xaperez100's Avatar
No you don't turn it on. Just leave it off and take a picture because if you don't put them in the right spot where they begin they will be off like my mph is a little off and I can't get it back to normal idk why-.- but just make sure they are at the same spot as they should be when you took them off. You could mark it with something if you wanted just make sure you can rub it off after. Once you get the needle on you can turn it and let go it should go back down to the same spot but some of them don't move back so be careful if you don't take a picture lol
Old 02-06-2013, 10:16 PM   #22
Sluder4's Avatar
Are these the lights for the dome? I'm wanting green
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 02-06-2013, 10:19 PM   #23
Xaperez100's Avatar
I think the dome have a tube like light bulb
Old 02-06-2013, 10:22 PM   #24
Sluder4's Avatar
He said seven dollars and that's in my price range. Do you happen to know what they are called exactly?
Old 02-06-2013, 10:23 PM   #25
Rcary's Avatar
Heres the install. I dont remember what the pre 2005's dome looks like but i figure its similar to this
Mustang LED Dome Lights Installation - YouTube
Old 02-06-2013, 10:44 PM   #26
Xaperez100's Avatar
Nah man I'm not sure and they shouldn't be a different price you used to be able to get them at autozone for $3 they're little tubes I'm not sure what they're called but SBL has them
Old 02-06-2013, 10:45 PM   #27
Rcary's Avatar
I think mine were recon and they were like $10-$12 when I bought em
Old 02-06-2013, 11:09 PM   #28
Xaperez100's Avatar
Well for my cluster I paid $13 for 5 bulbs
Old 02-07-2013, 06:21 AM   #29
Sluder4's Avatar
How can you find out what bulbs will work?
Old 02-07-2013, 06:43 AM   #30
v8pony's Avatar
Can u pick up these lights at a radioshack or something similar?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 02-07-2013, 10:14 AM   #31
Xaperez100's Avatar
Yeah but then I don't think they have the colored ones. But I'll look for them.
Old 02-07-2013, 10:28 AM   #32
Adogg's Avatar
This looks great do you think it will be easy in my 94 gt ? If so has any one done it on a model year near mine?
Don't hate....... appreciate
Old 02-07-2013, 10:35 AM   #33
v8pony's Avatar
What kind of lights are they, do you have some sort of product # or something for them, I wanna go look today for some reds when I get home
2002 5spd GT
Old 02-07-2013, 10:35 AM   #34
97cutomstang's Avatar
I did blue LEDs in my 97. Got all my bulbs from eBay.
97cutomstang is offline   Reply With Quote
Old 02-07-2013, 10:57 AM   #35
Adogg's Avatar
Nice man was it hard to get the dome light off?
08:33 AM
