3.8 - 4.6 Swap, Trans woes - Mustang Evolution
Old 02-06-2013, 09:05 PM   #1
rkdrummerkid's Avatar
I have 1998 3.8 with a T5 manual trans. If I were to get my hands on a 99-04 4.6, would it work with my current transmission? Either way, what would be the best route to do this?
rkdrummerkid is offline   Reply With Quote
Old 02-07-2013, 08:04 AM   #2
runvsofthisbull's Avatar
Some ppl say the torque rating on the T5 that comes with the V6 is not as strong as the T-45/T-3650 that came with the 4.6's, but depending on the year I think the T-5 is rated at 300 ft/lbs. You would most likely need the correct bellhousing and flywheel though from a 4.6 Trans. You can probably use the bellhousing, but I would think you would need a flywheel to balance the motor correctly and to ensure that the starter will engage correctly. I don't have the specifics on the parts you need, but those would be a good starting area. The T-45/T-3650 that came in the 99-04 GTs are rated at 325 fl/lbs torque.
2002 True Blue V6 to GT Vert
16.1@86 as an auto 3.8
Old 02-07-2013, 04:22 PM   #3
Region: Alaska
The T5 transmission will not bolt on to the 4.6/5.4 engine block. The bell housings for the t5 came in the 302 and 3.8 bolt pattern. You will need either a t-45, t-3650, or the six speed t-56
Underpressure is offline   Reply With Quote
« Windstar | 5.0 swap »
10:45 PM
