95 mustang crank sensor?????? - Mustang Evolution
Old 02-11-2013, 09:26 AM   #1
Mustang was not running at all replaced the camshaft sensor it started right up. Now it's not running again. It happened after the degas bottle was taken off and cleaned then put back on. Any ideas? I'll add more info later. My friend is the one working on it. Thanks for any suggestions.***There is a loose wire under the intake on the left side of the motor (drivers side) it is a white wire with a pink strip up it not sure where it goes. The fans on the car are running constantly when car is turned on. Has anyone had any luck with duralast cam shaft positioning sensors? Any suggestions?
jennaeM95 is offline   Reply With Quote
10:04 PM
