cam shaft positioning sensor please help!!! - Mustang Evolution
Old 02-11-2013, 06:15 PM   #1
Mustang was not running at all replaced the camshaft sensor it started right up. Now it's not running again. It happened after the degas bottle was taken off and cleaned then put back on. Any ideas? I'll add more info later. My friend is the one working on it. Thanks for any suggestions.***There is a loose wire under the intake on the left side of the motor (drivers side) it is a white wire with a pink strip up it not sure where it goes. The fans on the car are running constantly when car is turned on. Has anyone had any luck with duralast cam shaft positioning sensors? Any suggestions?
jennaeM95 is offline   Reply With Quote
Old 02-12-2013, 08:02 PM   #2
Someone please help!
Old 02-12-2013, 08:56 PM   #3
1slosix's Avatar
pic of wire? what model v6?
carving corners like a boss
Old 02-12-2013, 09:15 PM   #4
Yes v6 it is a wire that is disconnected from something. He cannot find out where it goes. It is white with a pink stripe.
Old 02-13-2013, 06:31 AM   #5
1slosix's Avatar
What year v6? And ill look under my hood...but a pic would help.
Old 02-13-2013, 06:55 AM   #6
Crowned1's Avatar
well if you were sure it was that and it didn't help then id take it out to a mechanic now have him run a diagnostic and see what code your cars computer throws back at him.
Crowned1 is offline   Reply With Quote
Old 02-13-2013, 07:05 AM   #7
Crowned1's Avatar
that wire may be apart of the ignition switch but don't quote me on that!
Old 02-14-2013, 09:31 AM   #8
Project Pony's Avatar
Pink wire with white stripe on the driver's side of the motor goes to the coil pack.
---------- Post added at 11:31 AM ---------- Previous post was at 11:31 AM ----------
Nevermind, you said white with a pink stripe.
[SIGPIC][/SIGPIC]
Old 02-15-2013, 10:33 PM   #9
It is sitting at my friends house he is a mechanic. The best I know. lol He is taking the part back to Auto"bone" and getting a new one.
---------- Post added at 12:30 AM ---------- Previous post was at 12:29 AM ----------
Thank you and that's all that I can find about that wire is the ignition switch or starter.
---------- Post added at 12:32 AM ---------- Previous post was at 12:30 AM ----------
It is a 95 V6 Mustang Thank you!
---------- Post added at 12:32 AM ---------- Previous post was at 12:32 AM ----------
---------- Post added at 12:33 AM ---------- Previous post was at 12:32 AM ----------
11:12 AM
