Starting problems - Mustang Evolution
Old 02-12-2013, 03:50 PM   #1
Xaperez100's Avatar
Starting problems
Wondering why my car takes a while to start and if anyone knows why?
When I first drive it everyday it always takes a while to start up. Sometimes ill have to let off and start again then it'll start right up. And if I leave it sitting for longer than 30 minutes it'll take a while to start again as well..
U have a new starter In and my alternator reads 13.7/8 when the car is running.
Xaperez100 is offline   Reply With Quote
Old 02-12-2013, 04:38 PM   #2
Skargon's Avatar
All of the connections tight on the starter/alternator/battery Etc?
1998 Mustang V6
CAI, Exhaust, Weight Reduction
16.5 1/4 Mile
Skargon is offline   Reply With Quote
Old 02-12-2013, 04:39 PM   #3
1slosix's Avatar
get a systems check run at any auto parts store...make sure there's no ripple happening that'd drain it
carving corners like a boss
Old 02-12-2013, 05:47 PM   #4
Xaperez100's Avatar
Yeah everything's good! Sometimes the little plug that goes into the alternator comes loose but I just push it back in. But that doesn't make a difference. And they've checked only code I get is the egr but that's not deleted so idk why it throws it
Old 02-12-2013, 06:08 PM   #5
Mr_Trigger3.8's Avatar
It's possible it could be a weak fuel pump or possibly a clogged fuel filter. How many miles does your car have?
Mr_Trigger3.8 is offline   Reply With Quote
Old 02-12-2013, 08:11 PM   #6
Xaperez100's Avatar
Lol 138xxx
It's been a daily since it was brand new and kept in the family.. But yeah possibly the fuel pump is going bad. Fuel filters fine
Old 02-12-2013, 08:52 PM   #7
Lol 138xxx
Yea mine has been a little touchy in the mornings every now and then. I'm gonna be replacing the pump soon along with the filter. If you replace the pump might as well replace the filter as well.
Old 02-12-2013, 08:55 PM   #8
1slosix's Avatar
I didnt say get your codes read lol i said system check...that way they can test your charging and starting system
Old 02-12-2013, 10:07 PM   #9
Xaperez100's Avatar
Oh okay yeah I guess I should just do that as well:p
Old 02-28-2013, 11:20 PM   #10
So how's your stang doin? You get the problem figured out yet?
Old 03-01-2013, 12:19 AM   #11
Xaperez100's Avatar
I'm pretty sure it's my fuel pump but then I'm not sure because when it's cold outside it starts like nothing but when it's hot it'll take a while but then if I turn the car off for about 5 minutes and start it again even if it's hot it'll start right up. Idk but I ordered a new fuel pump so we will see what's happening. But so far she's running and looking great!
03:19 PM
