Brakes!? - Mustang Evolution
Old 02-12-2013, 05:39 PM   #1
BlackSmoke02's Avatar
Brakes!?
My rear brakes and sometimes my front ones screech whenever I press the brakes but ive checked them over and the all brake pads are only about 6months old and have a lot of pad still. Any opinions on what it might be?
BlackSmoke02 is offline   Reply With Quote
Old 02-12-2013, 07:43 PM   #2
twotone01's Avatar
Did you put your brakes in yourself?
twotone01 is offline   Reply With Quote
Old 02-12-2013, 07:47 PM   #3
1slosix's Avatar
Are all the slides well lubed? Hows the rotors?
carving corners like a boss
Old 02-12-2013, 08:04 PM   #4
Yeah I put them in myself. Yes they look adequately lubed. The rotors seem fine no abnormal lining or wasting.
Old 02-12-2013, 08:11 PM   #5
What type of brake pads? Some of the higher performance brake pads squeak louder than others.
Old 02-12-2013, 08:16 PM   #6
I want to say the autozone duralast gold? They were quiet at first and now I could kinda hear them squeak
---------- Post added at 07:16 PM ---------- Previous post was at 07:15 PM ----------
I could say they werent the cheapest though
Old 02-12-2013, 08:42 PM   #7
1slosix's Avatar
how's the fluid look? what color is it?
Old 02-12-2013, 09:00 PM   #8
Cobrarunnin9s's Avatar
Did you put the little silver clip back in the caliper before you put the pads back on, and also don't just lube the slides, lube anywhere metal to metal contact will happen.
Cobrarunnin9s is offline   Reply With Quote
Old 02-13-2013, 04:02 PM   #9
Torchredfrankie's Avatar
I had this issue it's just bake dust that gets in between the pads or on the rotors just give it a wash and clean your wheels and bakes you should be good.
Torchredfrankie is offline   Reply With Quote
Old 02-13-2013, 08:26 PM   #10
The brake fluid? Reddish I believe the last time I checked it
Yeah everything went bacck into it and lubed it all
Oh I see must vlean them soin then. How about this antisqueek brake spray? Any good?
Old 02-14-2013, 10:32 AM   #11
twotone01's Avatar
You could try the spray, but dd you make she to line up the little nipples on the rear and front?
Old 02-14-2013, 01:23 PM   #12
Yeah it all went back correct I had my dad look over since hes done some brake jobs in the past
Old 02-14-2013, 02:57 PM   #13
1slosix's Avatar
Red fluid could be from rubber breaking down...if it gets darker then you know its so. 99% of fluid is clear/opaque...
Old 02-14-2013, 04:01 PM   #14
The best to check for now would be cleaning them and the rotor and using a antisqueek spray then?
Old 02-14-2013, 04:36 PM   #15
1slosix's Avatar
anti-squeak is ok, but if there was any cosmosline left on your rotors during install that could explain the squeal. it can cause the pads to crystalize
Old 02-14-2013, 05:35 PM   #16
And what would be the best way to clean a rotor? If the anti-squeek lubricant got onto the rotor do you think during braking it'll slip or something and not stop? Im scared it might thats why ive waited lol
Old 02-14-2013, 07:05 PM   #17
Dantheman94's Avatar
Oddly enough if you get any kind of lube on your pads or rotors it'll make the brakes grap and lockup not slip. And is the squealing all of the time?
Dantheman94 is offline   Reply With Quote
Old 02-14-2013, 07:33 PM   #18
1slosix's Avatar
brake parts cleaner will clean the rotors nicely
Old 02-14-2013, 07:54 PM   #19
I should clean them first to see if it goes away then
Yeah well 80% of the time if I brake then release them and start to brake again it seems to quiet down a bit
Old 02-14-2013, 08:42 PM   #20
Also if you chamfer the ends of the pads it will help with squealing as well. And you may need to take a whiz wheel to the rotors to knock off the glaze.
Old 02-14-2013, 08:59 PM   #21
What do you mean whiz wheel?
Old 02-14-2013, 09:14 PM   #22
A small angle grinder with a quick change sanding disc on it
Old 02-15-2013, 12:10 AM   #23
Oh I see ill try cleaning it tomorrow and see if anything fixes the annoying sound
07:26 PM
