Burning Out? - Mustang Evolution
Old 02-12-2013, 05:54 PM   #1
BlackSmoke02's Avatar
Burning Out?
How come mustangs burn from only one rear wheel? Is there any way to make it do both?
BlackSmoke02 is offline   Reply With Quote
Old 02-12-2013, 06:38 PM   #2
slonison's Avatar
The v6 mustang has an open differential. meaning that power is only delivered to the passengers side rear wheel.
V8 Mustangs have a limited-slip differential. meaning that power is delivered to both rear wheels.
slonison is offline   Reply With Quote
Old 02-12-2013, 06:45 PM   #3
You always could drop in a t-lok
99whitev6 is offline   Reply With Quote
Old 02-12-2013, 06:55 PM   #4
What is a t-lok?
Old 02-12-2013, 07:01 PM   #5
It locks the non burning tire so both tires spin at once...will have the link to you shirtly
---------- Post added at 09:01 PM ---------- Previous post was at 08:58 PM ----------
http://www.americanmuscle.com/mustang-lsd-9904.html
Old 02-12-2013, 07:17 PM   #6
T-lok is short for Traction lock, where both wheels get power. Up until 2010 all V6 Mustangs came with an Open differential, which is where when traction is lost power is diverted to a certain wheel to maintain traction. All while the GTs came with a Limited Slip differential, in 2011 they actually changed that and now both V6 and V8 Mustangs have a Limited Slip differential.
Old 02-12-2013, 08:02 PM   #7
Seems a little expensive. Might have to start saving up so I could have more fun. Haha Thanks for the info
Old 02-12-2013, 08:04 PM   #8
You could also go to a junkyard/pick and pull yard and get a 8.8" rear end from a gt
---------- Post added at 10:04 PM ---------- Previous post was at 10:03 PM ----------
Sometimes it could be cheaper
Old 02-12-2013, 08:12 PM   #9
Does it have written on it the 8.8? Or would just any from a 99-04 gt fit?
Old 02-12-2013, 08:12 PM   #10
I believe an 8.8 from an F150 a similar year will fit also.
Old 02-12-2013, 08:17 PM   #11
93slowstang's Avatar
The chunk is offset so it won't work.
Old 02-12-2013, 08:18 PM   #12
+1
Old 02-12-2013, 08:30 PM   #13
In case I do find a gt one is thrre any modifying or needed supplies to it? Or Is it just a remove replace type of thing
Old 02-12-2013, 11:09 PM   #14
slonison's Avatar
Check my build thread. Its in there somewhere...
Old 02-13-2013, 05:38 AM   #15
Yessir that dould work also...plus the 8.8 will handle a hell of alot more power
---------- Post added at 07:38 AM ---------- Previous post was at 07:36 AM ----------
A gt 8.8 will tuck in no problem no mods needed
Old 02-13-2013, 08:29 PM   #16
Gotta start looking for it soon then! Thanks for the tips
04:44 AM
