Engine Oil Question - Mustang Evolution
Old 07-16-2008, 11:49 PM   #1
Question Engine Oil Question
Is this Royal Purple Stuff as good as it says it is? Is it really worth the 6-7 dollars per quart?
drkchocolate07 is offline   Reply With Quote
Old 07-17-2008, 06:25 AM   #2
Re: Engine Oil Question
i will not run royal purple, ive found the gear fluid makes rearend clutches slip, & my tremec 3650 ate syncros when i put it in there....so i dont trust it in anything else.
SimplyOrange is offline   Reply With Quote
Old 07-17-2008, 06:49 AM   #3
Its really good, every article ive read where independent studies are done it seems to come out on top. I have also heard some people have issues with it and such. For me I just use Mobile 1 full synthetic
Old 07-17-2008, 07:07 AM   #4
mobile 1 is great, i use castrol synthetic.but i used to use mobile 1
Old 07-17-2008, 09:45 AM   #5
Thank you but my I ask why did you switsh from mobil to castrol? And is full synthetic really as good as everyone says it is?
Old 07-17-2008, 10:06 AM   #6
no particular reason, the shop i work at stocks castrol and when i put my new motor in, i just poured what we had in stock in it, i approve of castrol or mobile 1, but once i use an oil on an engine, i dont switch to another brand.
what ive been told about the royal purple,particular the thin ones like 5w-20, is that it is so slick that it doesent create the film on the bearings and cylider walls because it doesentstick as much, kinda like putting water on a freshly waxed car, it doesent stay covering the whole surface, it beads and runs down.i cant see that being good for a piston ring.
Old 07-17-2008, 10:21 AM   #7
Okay thank you very much!!!!!
Battery/engine/oil leakeage problems? blackhawk Pre-2005 V6 Mustang 2 01-09-2010 05:50 AM
Engine Oil bittydrew 1996-2004 Mustang GT 16 05-09-2007 12:23 AM
Oil pan question... lowflyn Pre-2005 V6 Mustang 9 03-15-2006 05:14 PM
Oil recomendations/ Check engine light Neptuno Pre-2005 V6 Mustang 6 09-03-2004 08:09 AM
High Mileage engine oil DropTop_Stang Pre-2005 V6 Mustang 0 10-24-2003 07:17 PM
07:15 AM
