CEL HELP - Mustang Evolution
Old 02-16-2013, 03:15 PM   #1
Dbr4life's Avatar
CEL HELP
My 98 3.8 v6 is giving me a P0131 and P0443 had to replace IAC because it was damaged on the inside and replace all vacuum lines all the way to canister, just looking for a little direction or anybody that has had these codes before, still reading into what VMV circuit fault is but just thought I'd see If anybody had any helpful info . Thanks!!!!
Dbr4life is offline   Reply With Quote
Old 02-16-2013, 04:16 PM   #2
tonyd01gt's Avatar
Hi, the DTC , po131 is O2 sensor on bank 1. and the po443 is the purge control valve. Check the purge control solenoid to make sure it is working .the solenoid maybe causing your car to run lean or rich. throwing off the O2.
tonyd01gt is offline   Reply With Quote
Old 02-16-2013, 04:54 PM   #3
Dbr4life's Avatar
Made a mistake posting codes it's P1131 and P1443
Old 02-16-2013, 06:35 PM   #4
Dbr4life's Avatar
Replaced purge valve solenoid and got rid of 443 code still reading the 131 code but CEL hasn't come back on yet only driven it twice since I deleted codes and replaced solenoid
Old 03-05-2013, 07:51 AM   #5
Don't forget to check the rubber tubing that connects everything; if dry rotted it will need to be replaced.
Cheers......
jgwalker is offline   Reply With Quote
05:41 PM
