Help!? - Mustang Evolution
Old 02-17-2013, 08:00 PM   #1
Anthony8994's Avatar
Help!?
can I put a 1999 motor in a 1994 body( 3.8 same size) without changing stuff like the o2 sensor and mass air flow and chip? or will they just fit right in there smoothly?
Anthony8994 is offline   Reply With Quote
Old 02-17-2013, 08:49 PM   #2
1slosix's Avatar
you'll need everything from the 99
carving corners like a boss
Old 02-18-2013, 03:48 AM   #3
I heard you could do it but the only thing is your check engine light would be on and I really don't care of my check engine light is on but can I make the transition without changing the others?
Old 02-18-2013, 04:07 AM   #4
lemons95's Avatar
you could just use the new 3.8 block and use your old 3.8's heads and intake.
You wouldn't gain much. just a different balancing system and a SLIGHTLY different cam.
best swap you could do is probably 4.2 swap. You can re-use your old heads and intake. The power was very noticeable when I did it.
Old 02-18-2013, 06:52 AM   #5
1slosix's Avatar
Hopefully a second opinion will chime in but pretty sure youll need almost everything.
Old 02-19-2013, 05:21 PM   #6
Yeah man you will need everything...the old computer will not even recognize the new engine
99whitev6 is offline   Reply With Quote
« Take off | CAI ! »
» Members Mustangs
Roy
blubill
AzzKikr
rjrbsn
Add your Mustang
06:42 AM
