What is a good cai - Mustang Evolution
Old 02-18-2013, 10:55 PM   #1
greenstang41's Avatar
What is a good cai
I want an intake where you can c the filter
And a power gain
greenstang41 is offline   Reply With Quote
Old 02-18-2013, 11:00 PM   #2
willrad00's Avatar
Really any of the ones on AM will work, you wont get any really noticable gains off a just a CAI so alt of guys just buy the AM one.
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 02-18-2013, 11:09 PM   #3
Venomouz831's Avatar
Knn has ram air
)02 Gt, Founder of WE2G
Old 02-19-2013, 01:07 AM   #4
Skargon's Avatar
BAM! Get a Cheap CAI from Ebay or AmericanMuscle.com and cut it, it's what I did.
I only did it because of issues with the plate not fitting properly for some reason..
1998 Mustang V6
CAI, Exhaust, Weight Reduction
16.5 1/4 Mile
Skargon is offline   Reply With Quote
Old 02-19-2013, 07:00 AM   #5
Crowned1's Avatar
And a power gain
can't go wrong with a bbk or k&n really any CAI made of plastic will be perfect and make sure to get that tune!
Crowned1 is offline   Reply With Quote
Old 02-19-2013, 07:17 AM   #6
Project Pony's Avatar
Generally if you can see the filter in the engine bay, then you have turned your cold air into into a hot air intake negating any gains you could have had.
[SIGPIC][/SIGPIC]
Old 02-19-2013, 08:50 AM   #7
Crowned1's Avatar
that too. the filter is hidden in the fender well for a reason.
Old 02-19-2013, 01:18 PM   #8
1slosix's Avatar
drop in filter in stock box does the trick unless you just want the "cool" factor of having a CAI
carving corners like a boss
Old 02-20-2013, 08:49 PM   #9
Torchredfrankie's Avatar
So your saying that the k&n intake is no good? Just because its not in the fender wall?
Torchredfrankie is offline   Reply With Quote
Old 02-20-2013, 10:44 PM   #10
Crowned1's Avatar
well IMO it's kind of the exception because it is made up of plastic and if you a thing or two about science. plastic is not a conductor of heat.
Old 02-20-2013, 11:13 PM   #11
1slosix's Avatar
won't matter what the tubing material is...air won't be in the tube long enough to change it's density
Old 02-21-2013, 04:24 AM   #12
Dgerow12's Avatar
99% of k & n CAI have a block off box that causes the intake to pull from the fenderwell more than the engine bay. I will try to find a picture to show what I'm talking about
Dgerow12 is offline   Reply With Quote
Old 02-21-2013, 04:26 AM   #13
Dgerow12's Avatar
Old 02-21-2013, 05:34 AM   #14
There ya go. While not optimal, its still much better than having a completely exposed filter just sitting in the bay. Its common sense. You dont want to pull hot air from the engine bay into your intake.
Lets break this down nice and simple like.
"COLD AIR" intake!
[SIGPIC][/SIGPIC]
Old 02-21-2013, 06:29 AM   #15
Crowned1's Avatar
still better than the stock though. ask yourself, is it really worth spending $200 on a CAI?...
cai
10:17 AM
