05 Convertible frame problems - Mustang Evolution
Old 07-19-2008, 01:48 PM   #1
Angry 05 Convertible frame problems
Have just found out that there was a problem with the design in the frame for the 05 Convertibles, that cause them to buckle. Any one else having a problem?
Only way to fix is supposedly replacing complete frame for $2500.00
msally05 is offline   Reply With Quote
Old 08-10-2008, 07:19 PM   #2
philup6968's Avatar
Re: 05 Convertible frame problems
i have an 05 convertible havent heard anything about this an i dont want to either!
MODS| MAC EXHAUST AND MORE TO COME
philup6968 is offline   Reply With Quote
Old 08-11-2008, 06:14 AM   #3
i think its bs about replacing the frame, they have a few companies making killer subframe connectors for those cars, i think granatelli is one of them, look into adding them if you are worried about it.i havent heard anything about this either, are you sure they didnt mean in a collision?
SimplyOrange is offline   Reply With Quote
Old 08-11-2008, 07:04 AM   #4
can you be more clear on the issue and what is supposed to cause it
Old 08-11-2008, 10:23 AM   #5
Not sure what caused it, but there is a TSB out on it The Side Rail LInkage is broken on the drivers side, when I took it to Ford, their only solution is a complete frame replacement at about $2500.00 I have found a private owned shop that says the part can be welded, and will be having him do the repair in the next few weeks. The TSB number is 07-17-8 My understanding from several shops that I have checked with, Ford knew about the problem, but will not stand behind it and do a recall. Hope this helps
Old 08-11-2008, 10:26 AM   #6
Thank you will check into that. I have a shop that says welding will correct the problem, but it means taking everything apart and being without the car for about 2 weeks. That is what is killing me the most.
Old 08-11-2008, 11:18 AM   #7
benjy has a set of the baddest subframes ive ever seen hanging on our shop wall, ill see if i can find you a link to a set, they will prevent it from happening again though.
Old 08-11-2008, 11:21 AM   #8
the ones on our wall are granatelli, heres a linky
Loading...
once welded in, you should definitly not see that problem again
Old 08-11-2008, 11:31 AM   #9
Thank you
New floor pan and Frame 68redcoupe Classic Mustangs 3 09-14-2010 07:07 PM
67 fastback owner - frame up here we go twisted_pretzel Classic Mustangs 1 02-01-2008 08:44 PM
wtb top frame for 91 vert flysure1 Mustang Parts for Sale and Wanted 0 12-27-2007 10:32 AM
68 Mustang front frame rail specs. brianb25 Classic Mustangs 1 09-19-2007 12:59 PM
frame alignment Dark02Pony Pre-2005 V6 Mustang 13 12-20-2005 10:12 AM
08:08 PM
