quest for 13's n/a - Mustang Evolution
Old 07-19-2008, 02:52 PM   #1
quest for 13's n/a
my goal for the end of this year is to run in the 13's n/a with my 02 auto v6.
here are my current mods:
frpp 4.10s/posi-trac diff, sct livewire, bbk shorties, flowmaster duals, k&n air filter, silencer removed.
now looking at that it isnt much, but here are my mods for the next couple months:
cnc ported heads(flow 253/170 cfm at .600), comp billet cam(224/224,112lsa,.548 lift), ported intakes(imrc removed,egr delete), hs 1.73rr's, 65mm halfshafted tb, mac lt headers/o/r h-pipe, flow 40s dumped, dyno tune, asp 25% underdrive pulley, eibach springs, qa1 kmember, and upr upper/lower control arms.
im also thinking of doing this a little later:
tci 3000 stall converter, j-mod, tranny cooler, aluminum driveshaft, remove front sway bar/spare tire/jack, rear seat delete.
i guess im hoping this will be enough. so what do you guys think. im trying to get all i can n/a, then boost sometime early next year.
tigerfan2771 is offline   Reply With Quote
Old 07-19-2008, 04:03 PM   #2
1234's Avatar
Re: quest for 13's n/a
Cant wait to see the times. And pics of the car. I think it will do it.
Old 07-19-2008, 04:46 PM   #3
also, would you guys recommend the tci converter or an edge racing converter? and what are some other mods that will lower my times and not cause me to spend a fortune? im thinking some lakewood shocks/struts.
Old 07-20-2008, 01:47 PM   #4
Send a message via AIM to VCS_SSSTANG
Some good tires and stall and you should be able to hit a 13, prob a high 13 but a 13.
VCS_SSSTANG is offline   Reply With Quote
Old 07-20-2008, 01:54 PM   #5
yea it doesnt matter high or low really. i just want a 13 second car. i should be buying some nitto 555r's for the two rear tires next spring, but until then my toyo proxes 4's will have to do. im mainly looking at what torque converter to buy. i dont wanna spend $900 for a multi-disc precision industries, but i still want a good lock-up converter. i was even thinking about getting the tci saturday night special, but i have no idea. as far as everything else, i have them all picked out.
Exhaust Setup Quest.? tex 2005-2010 Mustang GT 1 07-30-2006 10:17 AM
My exhaust quest is over! Rygen Pre-2005 V6 Mustang 21 04-01-2006 07:48 AM
Cobra R bk w/ lowering srpings quest. douGT Mustang Audio & Video 14 06-28-2005 09:57 AM
on the quest....... Kyle Pre-2005 V6 Mustang 8 05-14-2005 12:56 PM
How many people are here that are in 13's and below? v6stanger Pre-2005 V6 Mustang 2 10-16-2003 04:40 PM
03:12 PM
