v6 horrible mpg and preformance - Mustang Evolution
Old 02-21-2013, 06:02 PM   #1
tommygrubb2001's Avatar
ok, i have owned my v6 mustang for about a year now. the car has alway had issues which i have tried to fix. When we first got it the power steering pump needed replaced, we did that and it still squeals like a mother. The car has no power, very slow acceleration. I replaced spark plugs, and wires. the rpms was jumping so i cleaned the idle air control valve and replaced the gasket. also when i turn on the ac the rpms jump bad. also i replaced the fuel filter, and air filter. the mpg sucks!!!! drinks a quarter in like 20 miles. someone lead me in a good direction
tommygrubb2001 is offline   Reply With Quote
Old 02-21-2013, 06:06 PM   #2
v8pony's Avatar
Year mustang would help..mileage?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 02-21-2013, 06:08 PM   #3
i dont know why i forgot that, it is a 2001 auto. 118,000 miles
Old 02-21-2013, 06:10 PM   #4
v8pony's Avatar
Has the car always felt underpowered to you, or just recently?
2002 5spd GT
Old 02-21-2013, 06:14 PM   #5
35th GT's Avatar
I'd say do a motor swap.. A 4.6 isn't bad on gas and you'll have power and no more of these problems.. You can possibly buy a used police crown Victoria for really cheap and swap motors
35th GT is offline   Reply With Quote
Old 02-21-2013, 06:16 PM   #6
i cant afford a motor swap at this time, and it was always felt under powered, hard time going up hills, and feels so sluggish.
Old 02-21-2013, 06:45 PM   #7
PonyBoyV6's Avatar
Not sure if the 01's had a coil pack, but my 00 v6 was sluggish going up hills and from a dead launch. I didn't see you mention you replaced the coil pack either, so that might help. And perhaps anew fuel filter if you haven't already. I did that with my car, and it awoke a whole new animal. Nevermind on the fuel filter, did see you replaced it. My bad. But definitely try the coilpack.
PonyBoyV6 is offline   Reply With Quote
Old 02-21-2013, 06:48 PM   #8
1slosix's Avatar
To be honest i think your cats are clogged... it explains all of your symptoms
carving corners like a boss
Old 02-21-2013, 06:51 PM   #9
sam62893's Avatar
That thing is huge I don't think it will fit in the engine bay
As for the power loss. Do a complete tune up. Then get the vehicle diagnosed. And start replacing old parts from least expensive to most expensive. My car is the only NE (new edge) I've driven but I feel like my engine is underpowered too, like if something is holding it back
Old 02-21-2013, 06:54 PM   #10
1slosix's Avatar
That engine would fit lol..but in all seriousness im sticking with clogged cats. I bet if he temporarily cut the mains off its feel instantly better.
Old 02-21-2013, 06:59 PM   #11
PonyBoyV6's Avatar
Did not even think of clogged cats. Definitely a possibility. Would that not throw a code though?
Old 02-21-2013, 07:02 PM   #12
1slosix's Avatar
Depends..his CEL bulb could be blown...the fuse to it could be blown...wiring could be bad...could already have something rigged on the o2 sensors to keep from.throwimg codes from previous owner
Old 02-21-2013, 07:04 PM   #13
BlackSmoke02's Avatar
I have a few same symptoms. And I have a feeling it might be clogged catback. How do you unclog that?
BlackSmoke02 is offline   Reply With Quote
Old 02-21-2013, 07:07 PM   #14
1slosix's Avatar
You cant...so you either replace them or take them off and just put in tubing...if you dont have emissions that's always a fun choice. If you have emissions it can be easier to just buy some high flow cats and swap them out.
Old 02-21-2013, 07:08 PM   #15
sam62893's Avatar
Whoops, my bad. Those things look monstrous compared to the 3.8's i out cars. Maybe it just looks bigger.
Didn't you say that you can check if your cats are clogged by driving at night, and then checking under your car. If the cats are glowing they are clogged
Old 02-21-2013, 07:11 PM   #16
1slosix's Avatar
Yeah that trick can help....but it sometimes doesnt work. However its a great idea to try
Old 02-21-2013, 07:19 PM   #17
replaced the coil pack it went shot a couple months back, and the cel works cause when the coil pack pooped out i had the flashing cel stating it was misfiring. its annoying cause grandma cars just zoom past me like no tomorrow
Old 02-21-2013, 07:38 PM   #18
slow281
sixpac's Avatar
Region: Nebraska
The 4.6 is what the GTs have lol.
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 02-21-2013, 07:45 PM   #19
1slosix's Avatar
SLP High Flow Catalytic Converter Kit (96-10 Mustang) M31040 - Free Shipping!
just saying....with your mileage this is the most likely problem and this is a great fix if you have emissions...it's my plan when i redo my exhaust come spring
Old 02-21-2013, 07:49 PM   #20
sam62893's Avatar
Ahhh, I was at the junkyard today and I was taking a look at some crown Vic taxis/police cruisers and they look wider. It was just took on the eyes I see
Old 02-21-2013, 08:14 PM   #21
Blogger
99ford's Avatar
Out of curiosity have you checked to make sure that the brakes aren't dragging?
Old 02-21-2013, 08:24 PM   #22
i replaced both front brake calapiers pistons where sticking, so unless back ones was dragging no, which you would think i would hear grinding noise and such if the emergency breaks were dragging
Old 02-21-2013, 08:28 PM   #23
Boomdizzle's Avatar
Id definitely check the cats or I also believe in the coil pack theory. My sister had a focus that acted the same way and it ended up being that her plug wires had almost completely corroded. Replaced those and the car ran like a champ.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 02-21-2013, 09:00 PM   #24
Dantheman94's Avatar
What about a vacuum leak somewhere?
Dantheman94 is offline   Reply With Quote
Old 02-21-2013, 09:02 PM   #25
1slosix's Avatar
you'd be able to hear it if it's causing this much to happen
Old 02-22-2013, 12:20 AM   #26
Michaelgranlund's Avatar
Any idea on How much would that cost? Just like an estimate for putting it in and buying it
Michaelgranlund is offline   Reply With Quote
Old 02-22-2013, 12:21 AM   #27
1slosix's Avatar
lol use the search feature and you'll find loads of threads on the subject
Old 02-22-2013, 12:31 AM   #28
Haha i wouldn't do it I was just curious how such a procedure is even delt with
Old 02-22-2013, 11:48 AM   #29
Swar GT's Avatar
Region: Asia
The power steering pump issue is in all V6 99-04 amm the auto v6 is less powered than the manual ,, but u could pro..charge it or turbo..charge it for 4200 - 4500 $ and u may have 350 to 400 hp in wheel
Swar GT is offline   Reply With Quote
Old 02-22-2013, 01:59 PM   #30
kickerofdoom's Avatar
What your mpg?
Old 02-22-2013, 04:22 PM   #31
i drive about 20 miles a day and drain a quarter of a tank, when i got the car it was better on gas, but it seems to just get worse and worse
Old 02-22-2013, 05:19 PM   #32
slow281
sixpac's Avatar
Region: Nebraska
Figure out your exact MPg fill it up drive about 100 miles fill up again divide exact miles buy exact gallons put in..
2001 GT - True Blue
10:59 PM
