Drag car - Mustang Evolution
Old 02-21-2013, 10:08 PM   #1
sam62893's Avatar
Drag car
So I have 2 stangs. One; a 2001 V6 which is my DD, and another 66 inline 6 which is my project. Once I get my 66 on the road I'm thinking of parking my '01 and converting it strictly to a drag car. It is all stock except for a CAI. Where would be a good place to start? And what would I need? This isn't a get up and go project, it will be a long term project. Money or time won't be an issue, like I said, strictly drag, long term project. I want it to be a fast little V6, that would be able to keep up with other V6's on the track. I'm not looking to make a GT killer lol
Old 02-21-2013, 10:16 PM   #2
1slosix's Avatar
research, research, research.....and look into an m112
carving corners like a boss
Old 02-21-2013, 10:22 PM   #3
sam62893's Avatar
Yeah, I was hoping to get an idea of what other people have done. In the end it'll come down t what I want out of my car. I've read about it. Seems solid, that'll definitely go on my list.
Old 02-21-2013, 10:26 PM   #4
1slosix's Avatar
the only real drag v6 on this site is David...but he'll tell you boost or bust if it's an all out drag car
Old 02-21-2013, 10:48 PM   #5
Dtibbz22's Avatar
Put an 8 in it. Time vs money
Dtibbz22 is offline   Reply With Quote
Old 02-21-2013, 10:53 PM   #6
1slosix's Avatar
eh has it's pro's vs cons...an m112 on a v6 will weight less and put out more hp an tq then a v8 with the same mods...sure he'll run slower but i don't think anyone would complain with him running low 12's with a moderate build
Old 02-21-2013, 10:57 PM   #7
sam62893's Avatar
So basically max out the motor to full potential? Full bolt ons ETC.
---------- Post added at 12:57 AM ---------- Previous post was at 12:55 AM ----------
Yeah, might as well just get a GT if I put an 8 in it. I want to keep the V6. It my own personal enjoyment.
So if anything, my car would still be street legal?
And also, would a GT tranny fit an my motor? I heard that the GT tranny had a removable bell housing
Old 02-21-2013, 10:59 PM   #8
1slosix's Avatar
well my friends build was still legal if that helps
Old 02-21-2013, 11:11 PM   #9
sam62893's Avatar
Yeah, any input is helpful. Thanks. Now about the tranny, mine needs replacing and I can get a tranny from a '00 GT with 71K miles would that bolt on?
Old 02-22-2013, 12:26 AM   #10
davidcseifert's Avatar
Region: Arkansas
No that has a modular bolt pattern, can't use a gt trans
Gears are always a great start for acceleration, 8.8 swap with some 3.73's will be good since you plan on big power
Cleaning all the casting material inside the heads and intakes to ease flow helps, ported heads/intakes under boost can actually lower IATs, while it "decreases" boost it's still flowing the same amount of air, just less restriction, and more power. Something you can do is grab a spare set of heads and try it out yourself, cleaning it up is easy.
My preference is a centri blower as they can be intercooled on our cars and run more boost safer since its cooler air, the downfall of the M112 is no intercooler, 8psi is going to get very hot.
Or search around for a decently cheap turbo setup, they go around sometimes just have to keep your eyes and ears open lol
blower/new cam soon
Old 02-22-2013, 01:44 AM   #11
Dtibbz22's Avatar
I don't know much about the v6 what type of horsepower are we talking here with these mods. Block cracking? I understand you can make just about anything fast. Not to seem like an *** but if you could get a v6 into 12s how much work is required and if simple bolt ons allowed that wouldn't everyone be doing it. I'm just curious. I'm thinking twin turbo a 6 and get impressive drag times
Old 02-22-2013, 05:51 AM   #12
1slosix's Avatar
Honestly our blocks hold down impressive numbers...still trying to find the peak and its well past 450...as for what got him into low 12s
M112 10psi
All supporting add ons
4:10s
Big stall
Tune
4.2 build
Intake, exhaust
Suspension mods
Slicks
I almost bought that car a few years ago but i bought a different stang instead....still kicking myself over it.
Also not to sound mean but a twin turbo build is overkill. A single setup will give you all the hp you could need.
Old 02-22-2013, 06:08 AM   #13
M112 10psi
4:10s
Big stall
Tune
4.2 build
Intake, exhaust
Suspension mods
Slicks
The limit thus far has been the main caps. Over 500 they stretch and fail. Thats the problem gary schmidt kept having with his single turbo 4.2 setup. Was a mean car when it was running correctly though.
Old 02-22-2013, 06:44 AM   #14
sam62893's Avatar
I think that a lot of people don't do it because it gets pretty expensive. Looks like a good setup. I feel like I'm gonna shove a crapload of Benjamin's down my cars throat lol well I guess I'll get the tranny from an '02 V6
02:22 AM
