track times - Mustang Evolution
Old 02-22-2013, 11:57 AM   #1
stang916's Avatar
track times
I have 2004 auto with a Cai . Dual exhaust divorced with no mufflers.. and a bama tuner..
I ran 16.1 what can I do to get faster time without breaking the bank.
stang916 is offline   Reply With Quote
Old 02-22-2013, 11:58 AM   #2
Venomouz831's Avatar
Gears and tires
)02 Gt, Founder of WE2G
Old 02-22-2013, 12:00 PM   #3
stang916's Avatar
Tires?? How I'm runnin stock right now
Old 02-22-2013, 12:01 PM   #4
What was you're 60'?
Old 02-22-2013, 12:04 PM   #5
stang916's Avatar
I don't know lol...has anyone ran a auto with gears what kind of times do u get
Old 02-22-2013, 12:05 PM   #6
It should say in the time slip you're 60'. Well on my previous car was a 2 gt auto with 4.10 and I ran a 13.2 best.
Old 02-22-2013, 12:10 PM   #7
stang916's Avatar
U had a gt?? I have a 6 ..I won't see 13 unless I do a engine overhaul or procharge it
---------- Post added at 01:10 PM ---------- Previous post was at 01:09 PM ----------
Don't have time slips...another question is does it matter if I have divorced duals with no mufflers??
Old 02-22-2013, 12:19 PM   #8
1slosix's Avatar
i'm gonna say your tires must suck...i ran a 16 flat with just intake, exhaust, and some nittos on my auto. i'd look into picking up a set of stock v6 wheels for the rear and buying some street legal slicks. whats your suspension currently?
carving corners like a boss
Old 02-22-2013, 12:20 PM   #9
1slosix's Avatar
as for the muffler thing not really...you lose a bit of low end power but you make it up with increased top end
Old 02-22-2013, 12:24 PM   #10
Not it shouldn't matter. Like slow said what's you're suspension? Look into lowering it and control arms, as well as maybe putting it on a diet
Old 02-22-2013, 12:25 PM   #11
1slosix's Avatar
i was actually curious because it looks lowered in his avatar....depending on how he dropped it then he could be hurting his times
Old 02-22-2013, 12:28 PM   #12
stang916's Avatar
Lowered 1.5 all around...someone at the exhaust shop told me that one of the springs may he in upside down :'(
Old 02-22-2013, 12:29 PM   #13
1slosix's Avatar
pics of said spring...and what springs are you running? the spring rate could be hurting you on your launching
Old 02-22-2013, 12:32 PM   #14
stang916's Avatar
Hood is fiberglass trunk is stripped ..baby diet..but I'm not a small guy
---------- Post added at 01:29 PM ---------- Previous post was at 01:29 PM ----------
EBay springs FTW?
---------- Post added at 01:32 PM ---------- Previous post was at 01:29 PM ----------
Can u put wider tires on stock rims?? I wana put 275 in back and 245 in front
Old 02-22-2013, 12:33 PM   #15
1slosix's Avatar
stock hood is made of SMS so i'd say the fiberglass isn't much lighter but every bit helps. as for your times you can probably blame the times on your tires and springs (depending on the spring rate)...not the best idea to run a spring you don't know anything about. as for stripping the trunk i leave my trunk loaded to keep weight over the back tires. some empty them personal preference...when i did my 16 flat run i had jack, spare, and a 1/4 tank of gas
Old 02-22-2013, 12:34 PM   #16
1slosix's Avatar
EBay springs FTW?
when you say stock rims which stock rims?
Old 02-22-2013, 12:35 PM   #17
thats about spot on for your car in an auto~ just work on traction (60ft time is huge, every .1 off it is .2 off the quarter mile time)
Gears will help the most for the money spent, and get a tlok so both tires spin for better traction. bolt ons really dont do anything
Old 02-22-2013, 12:37 PM   #18
stang916's Avatar
I wana drop my car as low I can go..what springs are good? I have the stock 04 alloy rims plasti dipped black
Old 02-22-2013, 12:39 PM   #19
1slosix's Avatar
you know if you do that your times are gonna get worse since there will be barely any weight transfer
Old 02-22-2013, 12:40 PM   #20
1slosix's Avatar
and you're maxed out now on those wheels...you wanted wider tires buy new wheels. and for lower then you are now you'd want to look into coil overs not just doing new springs for the best ride
Old 02-22-2013, 12:41 PM   #21
stang916's Avatar
What do u mean?? I have subwoofers in the back .. and I'm a big guy so weight is not a problem lol..
Old 02-22-2013, 12:41 PM   #22
Rich04's Avatar
These ? Just dipped ?
Rich04 is offline   Reply With Quote
Old 02-22-2013, 12:42 PM   #23
1slosix's Avatar
what do you mean what do you mean so i can elaborate lol...so much going on
Old 02-22-2013, 12:42 PM   #24
stang916's Avatar
No mine have a cap in the center
Old 02-22-2013, 12:43 PM   #25
1slosix's Avatar
pics?
Old 02-22-2013, 12:43 PM   #26
stang916's Avatar
Weight transfer what u mean lol
Old 02-22-2013, 12:44 PM   #27
1slosix's Avatar
when you launch you need to be able to transfer weight to the back tires...the stiffer your suspension the worse it gets...for a road coarse or auto x car stiff is great...for drag you need a softer setup so it squats when it launches for the best times.
Old 02-22-2013, 12:45 PM   #28
stang916's Avatar
It won't let me attach pics..says styem crashed
ID:	92311   Click image for larger version
Old 02-22-2013, 12:46 PM   #29
1slosix's Avatar
i remember having those stockers...they are heavy big time...my first track experience was with those and swapping to lighter GT starfish wheels with better tires made a good difference.
Old 02-22-2013, 12:46 PM   #30
stang916's Avatar
ID:	92313   Click image for larger version
Old 02-22-2013, 12:47 PM   #31
stang916's Avatar
Spacers on back
Old 02-22-2013, 12:48 PM   #32
1slosix's Avatar
yeah adding spacers adds rotational mass to the back too which can slow ya down too....i'd say look on CL for a set of 99-00 GT wheels...you'll enjoy them much more for both looks and weight
Old 02-22-2013, 12:49 PM   #33
1slosix's Avatar
here's the GT wheels painted black with slicks on the back
Old 02-22-2013, 12:54 PM   #34
stang916's Avatar
I'll look into those..I want torque thrust bullits
Old 02-22-2013, 12:55 PM   #35
1slosix's Avatar
that's what i have now...only ran $1200 with tires. first time i've ever bought anything new lol
06:23 PM
