Service Engine Light. MIL Elim question - Mustang Evolution
Old 07-21-2008, 12:17 AM   #1
Scorpion1's Avatar
Well I really dont wanna drop $120 on MIL Elims or even more for a tune. Is there any other way to keep this light from coming on from the sensors? Also, whats so different about the mustangs that it kicks a light for pulling the cats? ive done this on my daytona, and my neon with no issues. The MAF im assuming? If thats the case is their a way to convert the 3.8 to a MAP car?
99 5SPD 3.8L
WiCK3D_SiX
Scorpion1 is offline   Reply With Quote
Old 07-21-2008, 06:33 AM   #2
Re: Service Engine Light. MIL Elim question
mils arent $120, they are more like $60, you have to have mil eliminators or a tuner to eliminate the rear o2s because the signal voltage increases and makes the computer confused, the mil just changes that signal back to the factory setting to trick the computer, the tuner will just eliminate the rear o2 completely.there is no other way to change it, its just how the computers operate.
SimplyOrange is offline   Reply With Quote
Old 07-21-2008, 01:04 PM   #3
Scorpion1's Avatar
Oh alright. Well my car only has 2 o2 sensors (pre-cat) the rears are already elimnated or somewhere else. So would I be ok to eliminate the cats then if its not throwing codes from this?
WiCK3D_SiX
Old 07-21-2008, 01:08 PM   #4
oh v6...if you dont have rear o2s then you have nothing to worry about, just get a catless midpipe.
Old 07-21-2008, 11:04 PM   #5
Scorpion1's Avatar
sweet, thanks for the clarification. Im wondering if my car is a bit of an oddball though because it also stops at 120mph. (nose dives a bit at this point) I found out when I paced a GT from 90-120 before he started pulling away. EDIT: I rechecked the 02's. There are 2 on the front of the mani's (front of motor) and 2 pre-cats emediately after the flanges. This change anything?
ID:	19548   Click image for larger version
WiCK3D_SiX
Old 07-22-2008, 06:58 AM   #6
actually, the things on the manifolds are egr pipes, the other two before the cats are o2s, if there arent any after the cats, you dont need mils. They are around 100 bucks.
Old 07-22-2008, 06:59 AM   #7
MILs will probably be the cheapest but... they are known to not work great
Old 07-22-2008, 07:15 AM   #8
does the v6 even need mils?
Old 07-22-2008, 07:20 AM   #9
Scorpion1's Avatar
lol I guess I should have looked at my manual. They make block off kits for the EGR? Im having trouble finding them along with pullies. Guess Im lookin like a real noob now haha.
WiCK3D_SiX
Old 07-22-2008, 07:42 AM   #10
if u want to delete the egr, just find some caps that cover the nipples, then get a programmer to turn the egr off and block all vaccume and egr holes.
Old 07-22-2008, 08:14 AM   #11
Send a message via AIM to VCS_SSSTANG
1.) Yep they make egr block off plates
2.) You need mils or a hand held tuner if your removing cats
VCS_SSSTANG is offline   Reply With Quote
Old 07-22-2008, 07:18 PM   #12
Scut95's Avatar
120 is where the speed limiter kicks in.....the computer won't allow the car to go any faster
Old 07-23-2008, 01:07 AM   #13
Scorpion1's Avatar
Makes sense, I was told it was 115 thats why I was a little baffled when I got the extra 5mph before the dive lol.
WiCK3D_SiX
Service engine light :( explicitrock General Mustang Discussion 0 07-15-2010 10:02 PM
Service Engine Soon Light dwalke 1996-2004 Mustang GT 2 10-22-2007 04:46 PM
service engine light OXstang11 Pre-2005 V6 Mustang 14 10-28-2005 04:29 PM
Service Engine Light Mustang Val Pre-2005 V6 Mustang 12 12-27-2003 06:52 AM
service engine soon light tek55 Pre-2005 V6 Mustang 4 11-13-2003 02:00 PM
02:30 AM
