Turbo vs supercharger - Mustang Evolution
Old 02-22-2013, 07:11 PM   #1
greenstang41's Avatar
Which give direct power
---------- Post added at 09:11 PM ---------- Previous post was at 09:11 PM ----------
Instant
greenstang41 is offline   Reply With Quote
Old 02-22-2013, 07:41 PM   #2
Burkeys96GT's Avatar
Supercharger is spooling as soon as you turn the key
Burkeys96GT is offline   Reply With Quote
Old 02-24-2013, 06:33 PM   #3
lemons95's Avatar
a super charger is powered with the belts, and has a direct connection to the engine.
a turbo makes very low boost at idle. You won't notice the turbo until they spool up.
A small turbo spools up very fast but puts out very low boost. Larger turbos spool up slower but give a lot more boost on the high end.
I like superchargers better. You get the power on the low end, instantly which would be fun for drag racing and burnouts.
Old 02-25-2013, 06:44 AM   #4
Crowned1's Avatar
right on point. I know this wasn't an option but how about twin turbo? you could have a bigger and smaller turbo that way turbo lag is reduced. plus I think we can have all agree blow off valves sound pretty sweet
Crowned1 is offline   Reply With Quote
Old 02-25-2013, 07:27 AM   #5
They both really give direct power, but it's just at different RPM ranges depending on what kind of turbo you get.
David00 is offline   Reply With Quote
Old 02-25-2013, 08:43 AM   #6
willrad00's Avatar
Turbos will you give more power at the same level of boost purely because superchargers suck power to make power. However like mentiond above a turbo wont make any power until it spools up (or very little). The only turbo kits i'm aware of for V6 mustangs are TMA turbos.
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 02-25-2013, 10:22 AM   #7
if you want the best down low in the rpm range power go with a positive displacment blower like a kenne bell or whipple, but they dont make kits for the 3.8L.... you can retro fit a M112 Eaton (root style not the same as twin screw and not as good) but they work and are cheap~ the issue is no cooling solution.... but you get 300rwhp pretty easy (no more though)
Centrifugal supercharges are fine, work good just dont have that down low kick compared to a positive disp. blower (root or twin screw style). Turbos are fine, but will cost WAY more.
01:35 AM
