oil leak around or behind harmonic balancer - Mustang Evolution
Old 02-22-2013, 08:45 PM   #1
tommygrubb2001's Avatar
harmonic balancer is tossing oil on the front of the engine, not loosing a lot of oil but it is messy. replaced front main seal to no sucsess. also there is like a ticking coming from the balancer?
tommygrubb2001 is offline   Reply With Quote
Old 02-23-2013, 02:02 AM   #2
davidcseifert's Avatar
Region: Arkansas
I've heard of the aftermarket balancers cracking before and causing problems.. Might be the cause of the sound
As to the oil, did you put any silicone in the inside of the hb opening before you reattached it? What about the bolt itself? Both should get a light coat to prevent leaks
blower/new cam soon
Old 02-23-2013, 06:03 PM   #3
i might have to get a hb puller and do that, idk what it is really
10:16 PM
