Help, rpm issue 2001 mustang - Mustang Evolution
Old 02-24-2013, 02:27 PM   #1
tommygrubb2001's Avatar
When the heat or AC is on. The rpm will jump from 700-1000 every 10 seconds or so. I took a video but don't know how to upload. any ideas what is causing the rpm jump? Or a fix
tommygrubb2001 is offline   Reply With Quote
Old 02-24-2013, 02:36 PM   #2
Xtrosity's Avatar
I wonder if it could be an IAC problem? A lot of idle problems on our cars are caused by dirty or worn out IAC valves. Weird that it is only when that ac or heat is on though.
Xtrosity is offline   Reply With Quote
Old 02-24-2013, 02:40 PM   #3
I have cleaned it multiple times, I may have to replace it. I want to make sure before I start spending cash. Would a bad compressor cause this?
Old 02-24-2013, 02:47 PM   #4
Xtrosity's Avatar
It could for the ac, but you're saying it happens while the heat is on too, so more then likely it isn't the compressor. Past that I'm not really sure. Maybe a few more people will be able to help.
Old 02-24-2013, 04:32 PM   #5
Dgerow12's Avatar
It is your AC compressor cycling on and off. When you run your your heat the compressor will cycle on and off my 2000 v6 and my 04 v6 both do it but the 04 is barely noticeable compared to the 2000. If you pop your hood and turn on your defroster you can watch you AC compressor pulley engage and disengage when the Rpms jump
Dgerow12 is offline   Reply With Quote
Old 02-24-2013, 04:39 PM   #6
My girlfriend has a 98 v6 and it don't do it at all. No rpm jump. Maybe a vacuum leak will cause this?
Old 02-24-2013, 04:41 PM   #7
Dgerow12's Avatar
Idk I've only seen it on new edge mustangs but working at a shop I've seen other cars do this as well
Old 02-24-2013, 04:45 PM   #8
I will just try to ignore it. I have 2 flowmaster super 44's. so it makes a god awful drone sound. Ha
---------- Post added at 05:45 PM ---------- Previous post was at 05:42 PM ----------
Also just thought of this it may be low on freon
Old 02-24-2013, 04:46 PM   #9
Dgerow12's Avatar
Yea they do. My 2000 did that. What year is yours? Seems the its a lot worse on the 99-00 than that 01-04
Old 02-24-2013, 04:54 PM   #10
Mine is a 2001, I neer thought about low freon, although I may have a leak in the system although it blows a tad bit of cold air out
Old 02-24-2013, 05:21 PM   #11
1slosix's Avatar
you could always buy a UV test kit...see if you can hunt down the leak that way
carving corners like a boss
Old 02-24-2013, 06:16 PM   #12
lemons95's Avatar
My 95 jumps down a little when I turn the A/C on. I haven't noticed it with the heater though.
2001 mustang
05:02 PM
