3.73 gears - Mustang Evolution
Old 02-25-2013, 06:00 PM   #1
stiffey's Avatar
3.73 gears
I have a 2001 Ford mustang 3.8. I want to Change gears to 3.73. I have 18x8 tires. How bad will speedometer be?
stiffey is offline   Reply With Quote
Old 02-25-2013, 06:04 PM   #2
Shouldn't be that bad, you will learn to adjust your speed. My truck has the speedo off and i learned the difference. But if you have an auto you will need a re-calibration because it will mess up the shift points.
Old 02-25-2013, 08:10 PM   #3
Crowned1's Avatar
auto or manual? you will also need to either swap rear ends to an 8.8 or swap to a limited slip
differential, get some gear oil and the bearing install kit.
Crowned1 is offline   Reply With Quote
Old 02-26-2013, 02:01 PM   #4
stiffey's Avatar
Auto. I will be getting a Ford racing traction-lok
Old 02-26-2013, 02:21 PM   #5
1slosix's Avatar
then you would want the recal...autos are touchy when it comes to gear changes...if it was a 5 speed adjusting your speed would be fine, but not with an auto...either buy a tuner or pay for the recal
carving corners like a boss
Old 02-26-2013, 02:30 PM   #6
stiffey's Avatar
Sweet. Would sct 3015 work well
Old 02-26-2013, 02:42 PM   #7
Crowned1's Avatar
yes sir. also the ford racing tlok is no longer being sold new. if you are buying online the only choice you have is the auburn LSD.
Old 02-26-2013, 02:52 PM   #8
stiffey's Avatar
Oh. Amazon had it for 444.00. I'll check that one out. Thanks.
Old 02-26-2013, 02:57 PM   #9
stiffey's Avatar
Not Amazon, www.Stangmods.com
Old 02-26-2013, 08:39 PM   #10
Crowned1's Avatar
yea it's a bummer. if you can find a GT rear off Craigslist go for that. a bit of a more solid rear end then all you need is the gears, gear oil, and the install kit
01:55 AM
