98 v6 sway bars - Mustang Evolution
Old 02-26-2013, 08:48 PM   #1
Fourloko530's Avatar
98 v6 sway bars
What are the goods in having a sway bar
Fourloko530 is offline   Reply With Quote
Old 02-26-2013, 10:05 PM   #2
1slosix's Avatar
it keeps the car stable and stiff in turns...
carving corners like a boss
Old 02-26-2013, 11:25 PM   #3
lemons95's Avatar
did they come with a option to have sway bars?
cause my 95 v6 has sway bars.
Old 02-26-2013, 11:29 PM   #4
1slosix's Avatar
all v6's will have a front sway bar...but not a rear sway (well i think 94-95 v6's may have also had a rear factory but im not 100%)....so one of the first things a v6 guy should do is buy a rear sway. the cheapest way is off of a GT...or you can buy a larger aftermarket unit. the difference is noticeable the first time you hit a corner hard
and of course through the years sway bars changed...some models had solid units, some hollow..some thicker then others as well
Old 02-27-2013, 12:35 AM   #5
Is it worth me buying a rear sway bar
Old 02-27-2013, 12:53 AM   #6
1slosix's Avatar
110% if you don't wanna buy an aftermarket look for a used GT one...you can find them in the $20-30 range in most cases
Old 02-27-2013, 01:59 PM   #7
Project Pony's Avatar
Yep, pulled mine from a gt at my local salvage yard for 20 bucks. Sanded it aand hit it with some red caliper paint and popped in on.
[SIGPIC][/SIGPIC]
Old 02-27-2013, 03:26 PM   #8
So what year one do i need mines a 98
Old 02-27-2013, 06:30 PM   #9
lemons95's Avatar
Mine has both front and rear sway bars.
You would want to look for 94-98 sway bars. MAYBE the 99-04 sway bars.
Old 02-27-2013, 06:49 PM   #10
Whats sway bar gonna do
Old 02-27-2013, 08:01 PM   #11
lemons95's Avatar
I think they help stiffen up the suspension.
Old 02-27-2013, 08:29 PM   #12
1slosix's Avatar
Any 94-04 sway bar will fit...as for what it does it stabalizes the car in corners.
Old 02-27-2013, 09:11 PM   #13
lemons95's Avatar
my mustang does handle pretty good, even with my ****ty suspension(When i had my WIDE tires on they would rub, and it rubsgoing over speed bumps and drags the front bumper with steep driveways.) I can't afford new suspension though...
Old 02-27-2013, 10:52 PM   #14
1slosix's Avatar
at least go buy some monroe shocks and struts...won't cost too much and you can get your car at least riding oem
Old 02-27-2013, 11:21 PM   #15
I just got new shocks and struts and springs shpuld just go toss a sway bar off a gt so i don't have to worry bout doing **** again
Old 02-28-2013, 07:45 AM   #16
you wont have one stock so just go to a pull a part junk yard, find a GT of your same year set 94-98 or perhaps even 99-04 fit not 100% sure on that) and yank it off and install it, there wont be a huge difference so dont spend a ton on it.
Old 02-28-2013, 08:31 AM   #17
kickerofdoom's Avatar
I have a 2001 v6 with gt sways bars you can take turns much harder
Old 02-28-2013, 08:55 AM   #18
Adogg's Avatar
Yea I have a front sway bar in my 94 gt I painted it white and it looks really good. So does that mean I have a rear one to?
Don't hate....... appreciate
Old 02-28-2013, 08:58 AM   #19
1slosix's Avatar
Go outside and look
Old 02-28-2013, 09:01 AM   #20
Adogg's Avatar
Go outside and look
Lol just about to start a 2hr and 45 min criminalistics class so maybe after hahaha
07:49 PM
