HID Problem - Mustang Evolution
Old 02-28-2013, 07:58 PM   #1
V6in's Avatar
HID Problem
So I've had 35w hids in for a few months now. But recently one goes out and it will come back on and its really annoying. I remember hearing about a relay harness that gives it constant power. Would I need this to solve the problem? Where can I get one or do I need two?
V6in is offline   Reply With Quote
Old 02-28-2013, 08:05 PM   #2
Mxrider's Avatar
It could be a few things.. The ballast could be going bad or just a bad connection. But I would try the relay and see if that works. I know on my car I have to start the car then turn on my lights otherwise the second hid will not have enough power to turn on. A relay can be bought on eBay for a good price.
Mxrider is offline   Reply With Quote
Old 02-28-2013, 08:10 PM   #3
V6in's Avatar
Ya idk the ballast is only 2 months old maybe lol.
Old 02-28-2013, 08:39 PM   #4
1slosix's Avatar
what brand kit? and you can buy a relay kit from DDM
carving corners like a boss
Old 02-28-2013, 08:52 PM   #5
V6in's Avatar
I got it from DDM
---------- Post added at 09:52 PM ---------- Previous post was at 09:49 PM ----------
And if I do get this which I think it will solve the problem after reading... Will any relay harness work or do I need an 880 one or what
Old 02-28-2013, 08:55 PM   #6
Mxrider's Avatar
Yeah but sometimes you just get bad ballasts depending on the brand. And I'm not totally sure but I think all the relays are the same plug and play with the two prongs. I've never personally used one because mine don't need one.
Old 02-28-2013, 10:28 PM   #7
1slosix's Avatar
hmm it's rare for a DDM ballast to have issues...however if you do end up having a faulty one remember they have lifetime warranty on them
Old 02-28-2013, 10:29 PM   #8
1slosix's Avatar
try swapping the ballasts with each other and see if the problem follows or stays to one side..that'll tell you what's up
Old 03-01-2013, 06:41 AM   #9
V6in's Avatar
Well its not just one, it's sometimes the other. Like I could have one out then turn them off and on again and the other is out. And sometimes they flicker.
Old 03-01-2013, 07:34 AM   #10
1slosix's Avatar
sounds like they aren't getting enough power
Old 03-01-2013, 07:39 AM   #11
V6in's Avatar
So I'm online and looking at the ddm relay... Its only $10 but on a lot of the other ones I was looking at you had to put your bulb size in. This one doesn't have that. So will it fit all or what?
Old 03-01-2013, 07:44 AM   #12
1slosix's Avatar
it should be fine..i was also looking at the error eliminators...i'm wondering if our cars have a fail safe to turn off the power to a bulb if it thinks it's drawing to much power...if so that'd fix it as well. i'll have to look into it
Old 03-01-2013, 07:51 AM   #13
V6in's Avatar
I think I'm just gonna buy the relay hopefully it works.
Old 03-01-2013, 07:53 AM   #14
1slosix's Avatar
keep us up to date
Old 03-01-2013, 07:56 AM   #15
V6in's Avatar
Will do
06:16 AM
