Wheels feel loose - Mustang Evolution
Old 03-02-2013, 02:14 PM   #1
SixStang702's Avatar
Region: Nevada
Wheels feel loose
Okay so it feels like one of my wheels is loose like one of them wants to come off but its weird cause I just put on the hub centric rings for my wheels and it started right after I put the wheels back on and the lugs are all tight should I yake the hub centric rings off? Its a 2003 v6 mustang btw
SixStang702 is offline   Reply With Quote
Old 03-03-2013, 05:49 PM   #2
Dantheman94's Avatar
Which wheel is it? And what's the purpose of the rings?
Dantheman94 is offline   Reply With Quote
Old 03-03-2013, 06:42 PM   #3
1slosix's Avatar
hubcentrics as in spacers? to be honest i had the same feeling after putting them on my old v6...took them off and sold them a few weeks later...take the wheels off and tq the spacers down to 100 ft lbs at least to be sure they aren't coming loose off the hub
carving corners like a boss
Old 03-03-2013, 07:49 PM   #4
Region: Nevada
No just the hubcentric rings that seat in the rim
---------- Post added at 06:49 PM ---------- Previous post was at 06:49 PM ----------
And it feela like its coming from the front
Old 03-03-2013, 08:51 PM   #5
Torchredfrankie's Avatar
Check your studs. my buddy's S2000 felt the same way and a stud broke off and made the wheel shake.
Torchredfrankie is offline   Reply With Quote
Old 03-03-2013, 08:53 PM   #6
1slosix's Avatar
i just hope your shaking ends better then my last stangs did...i lost a wheel on a highway after not finding the cause of a shake for 2 weeks...turned out to be the studs were wallowing the wheels because the nuts had backed off enough to sit so they'd feel tight due to the weight of the car on them, but loose enough that over a few weeks of driving caused a bad issue...it really sucks when you suddenly get passed by your driver rear wheel lol
Old 03-04-2013, 07:40 AM   #7
You may want to try jacking up the car and try tightening the lugs again. Sometimes you don't tighten them all the way and when you let the car down again the weight of the car pushing against the wheel will make it feel like the lugs are completely tight.
David00 is offline   Reply With Quote
Old 03-04-2013, 07:50 AM   #8
rebeltx's Avatar
Make sure you tighten energy thing in the correct order also. Not doing so makes it much harder to get all the lugs tightened down properly
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 03-04-2013, 08:38 AM   #9
Region: Nevada
Whats the ft-lb torque for our lugs?
Old 03-04-2013, 09:17 AM   #10
You might wanna check your ball joints and tie rods, man. Those go out too easy.
Pony Boy 3P8 is offline   Reply With Quote
Old 03-04-2013, 02:47 PM   #11
1slosix's Avatar
100
11:59 AM
