how to clean engine? - Mustang Evolution
Old 03-02-2013, 03:02 PM   #1
Jorge Hernandez's Avatar
Smile how to clean engine?
so I've never cleaned my cars engine before and i was thinking about it and I've decided to do it but I don't know what i need and how to do it any help? please its cuz i just bought my first mod ever for my stang a cold air intake and i want it to look nice when i install it so it wouldnt be all dirty please help
Jorge Hernandez is offline   Reply With Quote
Old 03-02-2013, 03:08 PM   #2
Luna1994's Avatar
Region: Utah
Use de greser rinse it with low pressure then put tire foam and it will be all shiny and pretty
Luna1994 is offline   Reply With Quote
Old 03-02-2013, 03:21 PM   #3
Alright thanks for the info
Old 03-02-2013, 03:58 PM   #4
1slosix's Avatar
Start the car up idle for 10 mins....turn off car pop hood. Cover the coil pack and alternator with plastic bags. Spray engine bay down with hose pipe...spray all of wet bay with simple green or mean green. Close hood for 10 mins....pop hood spray off again with hose...use a scrub brush and rag for hard to remove spots....brush off any standing water...remove plastic bags and then spray all plastic and rubber with f21 by turtle wax...step back and enjoy.
carving corners like a boss
Old 03-02-2013, 04:09 PM   #5
How much do u think the supplies cost ?
Old 03-03-2013, 05:32 PM   #6
Blakhwk's Avatar
I cleaned my engine using the GUNK degreaser an protector, two cans $3.99 each, you can follow the car's manual instructions like I did, cover the battery, the fuse box and the air intake and spray the gunk degreaser, wait 15 minutes and then rinse it with water, then use the gunk protector and your done! Check the link below.
http://youtu.be/lORPwC0HLr0
Visca Barça
Blakhwk is offline   Reply With Quote
Old 03-03-2013, 05:33 PM   #7
1slosix's Avatar
you won't spend over $20
Old 03-03-2013, 05:47 PM   #8
I wasted like 30 cuz all my rags were wet and I also bought a brush and car wash cuz I had run out and 2 bottles of engine degreeser one was the purple power and the second was the auto one engine degreeser
Old 03-03-2013, 06:44 PM   #9
1slosix's Avatar
sounds good...then once a month just pop the hood and touch up the engine bay with some spray cleaner
Old 03-03-2013, 06:54 PM   #10
OK thanks I will
Old 03-03-2013, 07:24 PM   #11
Blogger
99ford's Avatar
Here is my method to save you headaches, time and who knows what else..
Step 1. Make sure the engine is ice cold before starting.
You want it cool since there is a slight possibility that you can crack the engine block by throwing cold water on it.
Step 2. Cover fuse box, battery, distributor cap, air intake, and I cover the alternator as well. Plastic bags work well
Step 3. I spray the entire bay with simple green and then lightly brush with a soft brush or old rag.
Step 4. Lightly rinse, I hold the hose at an angle off to the side, keeping the nozzle on the lowest setting.
Step 5. Pull off plastic bags a little water might get onto those areas , but just wipe it up, and you'll be fine.
Step 6: Dry the bay with towels or forced air dryer (a leaf lower will work as long as the tube is clean)
At this point you have 2 options leave it alone, or dress it up to your liking! I personally like and use SprayWay instant shine because it looks great, and it doesn't attract dust.
Note: I usually do the engine first when detailing a car, it's not mandatory, but I don't love the job enough to go back and clean the overspray up.
Old 03-03-2013, 07:30 PM   #12
1slosix's Avatar
Im more about steam cleaning
Old 03-03-2013, 07:36 PM   #13
How does steam work?
Old 03-03-2013, 08:01 PM   #14
Blogger
99ford's Avatar
Steam just uses pressured water particles to do the job it does work but not everyone has a steam cleaner. Plus steam creates more moisture it seems like. That's my opinion on it. It does work not my favorite method, but it will work without using chemicals.
Old 03-03-2013, 08:14 PM   #15
1slosix's Avatar
actually without a steam cleaner handy i'll just warm up the car 15 mins prior to spraying...some won't due to the minute chance in the past you could crack a block doing that. however i've never had an issue with this method and use it on all the cars & trucks i detail to get a great deep clean. really rips into the grime without using lots of solvents
Old 03-03-2013, 08:17 PM   #16
Nice how much do they usually go for?
Old 03-03-2013, 08:21 PM   #17
1slosix's Avatar
around $30-40 at Walmart for a cheap hand held...just make sure when done you always wipe up the excess water that builds up anywhere
Old 03-03-2013, 08:30 PM   #18
Next time I go to Walmart I'll check it out
02:32 AM
