car doesn't turn on! - Mustang Evolution
Old 03-03-2013, 03:08 PM   #1
Berry_Eggo's Avatar
Ok so this morning i drove to my job and back right, no problem but when i tried turning it on earlier today my car just kept cranking but didn't run, so i sprayed starting fluid into my throttle and it ran while you reved it but i kept spraying the fluid into my throttle otherwise it would dye on me. I yhink it's my fuel pump? Any help?
Berry_Eggo is offline   Reply With Quote
Old 03-03-2013, 04:40 PM   #2
Pgfdv6's Avatar
It's the fuel pump literally just went threw this with mine
Pgfdv6 is offline   Reply With Quote
Old 03-03-2013, 04:51 PM   #3
1slosix's Avatar
when you put the car in on position have someone lay down near the tank to see if the pump primes...also check the fuel pump relay...could also be a fully clogged fuel filter
carving corners like a boss
10:35 PM
