Proper tune up - Mustang Evolution
Old 03-03-2013, 10:19 PM   #1
9stan5's Avatar
Proper tune up
What parts will i need for a proper under the hood tune up.?belts and hoses for a 95 v6 3.8?
9stan5 is offline   Reply With Quote
Old 03-03-2013, 10:28 PM   #2
I would replace the spark plugs, check the coils, sea foam it, check for cracks in the serpentine belt (if there are it will squeak when running), check/change all the fluids (coolants, oil, tranny fluid ect...) Probably more i'm forgetting.
Old 03-03-2013, 11:58 PM   #3
Differential fluid, along with engine, power steering, coolant, trans, ect... Air filter, fuel filter, plugs. Seafoam intake and gas tank. Everything else mentioned above by brother Soccer.
Old 03-04-2013, 12:05 AM   #4
9stan5's Avatar
Sounds good.
What's differential fluid for?
Old 03-04-2013, 12:12 AM   #5
The axle. The gears that make you go are in there. Key part to the whole function of car moving. Installing quality synthetic gear oil reduces drag, friction, sheer, lowers resistance. Very important and overlooked by many. There is a drain plug on side of housing. Fluid is removed by pumping it out, filled by adding till it gets to top of fill hole. Good luck!
Old 03-04-2013, 12:59 AM   #6
9stan5's Avatar
Jiffy lube had told me i was low and in need of refilling.i want my car to last me as long as possible.ill try to do some of those easy changes my self.
Old 03-04-2013, 01:40 AM   #7
EricJames's Avatar
+1
EricJames is offline   Reply With Quote
01:52 AM
