Driveshaft from van - Mustang Evolution
Old 03-06-2013, 03:37 PM   #1
twotone01's Avatar
Driveshaft from van
I've heard that some people take an aluminum drive shaft out of a van and put it in our cars but idk what van it's from. Does anyone know what I'm talking about haha? Thanks
twotone01 is offline   Reply With Quote
Old 03-06-2013, 03:52 PM   #2
brooksyx's Avatar
If I had to take a guess it would probably be a windstar. Seems like if you can pick up one of those from a junk yard you can swap out a lot of parts for some good performance upgrades lol.
brooksyx is offline   Reply With Quote
Old 03-06-2013, 04:56 PM   #3
I think the driveshaft from a van might be too long....
Old 03-06-2013, 05:37 PM   #4
Windstar is fwd, no driveshaft.
Old 03-06-2013, 05:48 PM   #5
1slosix's Avatar
you beat me to it
carving corners like a boss
Old 03-06-2013, 05:50 PM   #6
deadsp0t's Avatar
The older Aerostar vans are RWD? I still believe itd be too long
That's unimpressive
Old 03-06-2013, 05:51 PM   #7
I had the same thought. They are rwd but doubt its the right length.
Old 03-06-2013, 05:53 PM   #8
2300turboford's Avatar
You. Can always shorten them idk how much a machine shop charges
Old 03-06-2013, 07:08 PM   #9
At that point you might as well get yourself a new aluminum driveshaft that fits.
Old 03-06-2013, 07:17 PM   #10
deadsp0t's Avatar
For what it costs(in my area) to shorten an aluminum DS and balance it, you'd be $ for $ with a FRP unit and have a better shaft with the FRP unit.
That's unimpressive
Old 03-06-2013, 07:56 PM   #11
TM2189's Avatar
Aerostar is the van, If I remember correctly you only have to swap the yokes out.
TM2189 is offline   Reply With Quote
Old 03-06-2013, 09:21 PM   #12
twotone01's Avatar
I'll look into the specs because that'd be a cool junkyard mod lol thanks!
Old 03-08-2013, 07:13 PM   #13
Okay at first I was thinking this might be a hackjob but started thinking about it because I am related to someone who used to have a Aerostar.
Alright apparently if you get the driveshaft out of a AWD Aerostar it will be aluminum and it will fit the Mustang you just need to swap the yokes. The RWD Aerostar is the wrong size and if it is stock it will be a steel driveshaft. I remember thier being a problem with the steel shafts and a lot of them were swapped to a aftermarket aluminum shaft by the dealers. So if you go to a junkyard make sure you check what you are getting.
Redstang19 is offline   Reply With Quote
02:28 PM
