98 v6 swap with 99+ - Mustang Evolution
Old 03-08-2013, 09:22 AM   #1
98 v6 swap with 99+
I have read that the 99 - 04 models have the same block as the 98 v6 but dual port. Will a 2000 v6 3.8 bolt up to my current car, and secondly if it does I have planed on sinking some money into it with 315- 340 hp calculated for my first mods.( that is in a perfect senario) will the stock internals stand up to the horsepower, or if I invested in forged internals what would be the most hp I could safely run.
t.tuttle59 is offline   Reply With Quote
Old 03-08-2013, 09:57 AM   #2
1slosix's Avatar
Yes stock block can easily handle that...as for direct swap a few changes here and there but itll be a good swap. Also what mods do you plan to hit those numbers?
carving corners like a boss
Old 03-08-2013, 10:13 AM   #3
I am deciding between a supercharger or a turbo. But new headers, roller cam, cat back, I think new injectors. As this is my first big build I do not know if my math is right, but like I said if everything worked out in a perfect scenario that's about what it came out. Though if I'm wrong any and all advise would be welcome. I'm just trying to get my car to at least beat a stock gt easily
Old 03-08-2013, 04:12 PM   #4
sam62893's Avatar
I'm doing the same swap. An '02 motor into a '97 shell. As far as I've researched. You'd need the fuel lines and tank from a New Edge. I'm pretty sure the motor mounts are the same
Old 03-08-2013, 06:15 PM   #5
You will probably need the ECU too, I think it is different than the ones from pre - 99. But yeah not only could you kill a GT with that power you could kill some LS1's and other Camaro trash. Man I'm kind of jealous now lol.
Also a supercharger will probably hold out longer in the long run. A lot of turbo's do burn out before superchargers because of how they spin so fast all the time. A turbo setup is a lot easier to do I have been told.
Redstang19 is offline   Reply With Quote
Old 03-10-2013, 06:55 PM   #6
Thank you all for the help. For a time I was almost ready to by a 351, but after being ragged for having a v6 mustang I want my 6 to show them up. Since this is my daily driver what should I cap the HP to. I would like all that i could get but I want it also to be practical such as mpg and handling.
Old 03-10-2013, 06:57 PM   #7
sam62893's Avatar
Mpg and speed aren't you know... Compatible. You're going to sacrifice one for the other but you can get a decent speed with a decent mpg as well. Someone will chime in soon though
09:36 AM
