Squaky noise - Mustang Evolution
Old 03-09-2013, 02:58 AM   #1
Xaperez100's Avatar
Squaky noise
When I turn the steering wheel at low speeds below 20* it squeaks a lot. And it's annoying.. And after I found out I pushed down on the car to see where it was coming from and when I pushed Down it made the noise again. Sounded like the springs or something. Anyone know what it could be???
Xaperez100 is offline   Reply With Quote
Old 03-09-2013, 07:41 AM   #2
Yeah sounds like a suspension problem. Might be your springs, might be something else. If you lift the car and look at your springs and if they are rotted out at the bottom because it is easy to see on our cars then you will need springs, that could be the problem.
Redstang19 is offline   Reply With Quote
Old 03-09-2013, 10:45 AM   #3
Xaperez100's Avatar
Good thing my springs came in yesterday
Old 03-09-2013, 01:55 PM   #4
Wow right in time, tell us when you change them if the noise goes away.
Old 03-09-2013, 02:41 PM   #5
Tominkc's Avatar
Send a message via Yahoo to Tominkc
Since your changing your springs , check you control arm bushings . My car was making the same noise and after taking to shop that's what they were!! The same thing happened to a friends car,, I have a 2012GT, and my friend is a 2011!
Tominkc is offline   Reply With Quote
Old 03-09-2013, 02:50 PM   #6
Xaperez100's Avatar
Yeah I have my lower ball joints in also so ill be replacing those as well!
---------- Post added at 03:50 PM ---------- Previous post was at 03:50 PM ----------
Lol yeah I know:p I got home and they were on my bed:p but yeah I will let y'all know!
02:27 PM
