T5 Swap Next Weekend!!! - Mustang Evolution
Old 03-10-2013, 10:44 PM   #1
GDogg08's Avatar
After all the research i finally got all my parts in, next weekend I'm going to swap my auto to t5!!!
Wish me luck, ill post a tutorial after. I found alot of tutorials on how to do it, but none with an actual step by step video tutorial. If i can help a fellow pony rider it will be worth it.
Little worried tho, I'm not changing my ECU to a manual ECU because if i changed my ECU the car wouldn't start because the codes or whatever wouldn't match "I think its called PATS" which means i would have to tow the car to the dealer, either way i hope it starts and can be drivable for 10 miles to the dealership to get the auto codes flashed to the T5 settings!
GDogg08 is offline   Reply With Quote
Old 03-11-2013, 12:08 AM   #2
You can drive it with the auto computer. It will just freak out a bit and make you idle very high. And you'll only be able to go about 55 due to issues with overdrive messing up the speedo.
Pony Boy 3P8 is offline   Reply With Quote
Old 03-11-2013, 06:52 AM   #3
GDogg08's Avatar
not to bad then lol, i can handle that for 10 miles. Thanks for clearing that up!
Old 03-12-2013, 08:38 AM   #4
Crowned1's Avatar
if you don't mind me asking how much it cost total in parts?
Crowned1 is offline   Reply With Quote
Old 03-12-2013, 09:26 AM   #5
GDogg08's Avatar
roughly $1500 could have been less but i got performance clutch assembly, throw out bearing, pilot bearing, short throw shifter, shifter ball, and clutch cable. I got the tranny, driveshaft, bolts, pedal assembly, and wire harness from an auto salvage yard online for 800. The tranny only had 50,000 miles on it, everything worked. I recieve it all today "UPS" i have 300 on the back burner just in case i want to rebuilt the tranny before i put it in.
Ebay has a few of these swaps for 1600 - 2200 bucks problem is everything is bone stock parts. You gets everything NEW except tranny, drive shaft, and pedal assembly, and the tranny is rebuilt so that's good. But i didn't want to go that route because its still ford oem parts and i wanted a little more bang for the buck going aftermarket!
If you decide to do this plan ahead, if you know u will one day change the shifter or clutch, do it from the beginning to save you money.
i can give you a complete parts list of everything you need if you want!
Old 03-12-2013, 09:29 AM   #6
run an OEM ford throwout bearing or a heavey duty ford throwout, dont use the ones that come in clutch kits FYI, probably same for pilot bearing
Old 03-12-2013, 10:00 AM   #7
GDogg08's Avatar
Exactly!
i used oem on those but i was just saying i bought those brand new. At least that was what i was trying to say. The only aftermarket that arnt oem would be, clutch, flywheel, shifter "knob and boot" and a few gaskets.
i saved money going this route instead of going with that kit online, because i knew i wanted a few aftermarket performance parts and don't want to spend more money down the line.
Old 03-12-2013, 10:03 AM   #8
thanks in advance for the writeup, vids, and also snap a ton of pics. It will be a great addition, plus anyone wanted to know about your car/swap in the future can read it. Just have a good light source so we can see details in the pics lol.
Old 03-12-2013, 10:08 AM   #9
Project Pony's Avatar
+1 there are a lot of guys that for what ever reason acquired an auto, and want to convert it. A good write- would help them quite a bit. To either do the swap themselves, or at least give them a better idea of what is involved to better determine if they still want to do it.
[SIGPIC][/SIGPIC]
Old 03-12-2013, 10:22 AM   #10
GDogg08's Avatar
For sure im going to do all i can, I wish i would have bought a manual in the first place but i couldn't complain, my uncle bought the car brand new in 02, put 14,000 miles on it and has sat ever since in the garage. Sold it to me for 3500$. So i put 5G into the motor, "m112 supercharger, Powerpack stage 3 from supersix" change the rearend from 7.5 to 8.8 with 373 gears, and full LT headers and true dual exhaust. Now after the trans, i will just need a dyno tune then im done modding it.
I'm take pics of all the parts tonight, then video will come this weekend hopefully.
Old 03-17-2013, 01:03 PM   #11
GDogg08's Avatar
Alright Guys!
Update 1
I just want to say, it took me 10 hours to pull the old auto out "thats what happens when u have a few beers and BS with buddys" anyways, it came out last night, im putting the new one in today. Take auto out is alot harder than installing the smaller T5.
So far steps,
remove driveshaft, Ypipe, starter, wires connected to trans, shifter cable, rubber insert to get to the torque converter bolts, 4 torque converter bolts, bell housing bolts, driver seat, center console, shifter.
Taking the auto out isnt fun, for 1 reason its hard to get to the top 4 bellhousing bolts, 3 options, tuff it out with an openend 13mm wrench, get it from the back of the motor from inside the motor area, or get a 2-3 foot long extension with a swivel on the end.
I did tuffed it out except for the top 2 bolts which i used the biggest extension on the planet lol.
Anyways so far so good, you will see it once i get it all done and edit the video.
Sorry about spelling and stuff, my hands are so cut up and can barely type.
Old 03-17-2013, 01:10 PM   #12
Ghostedmind's Avatar
wow, im really excited to see this, I've been wanting to do this very same thing. Maybe this could be a sticky?
side note, I'd love to see the parts list if you can.
LCMC Member
Old 03-17-2013, 01:19 PM   #13
GDogg08's Avatar
Yeah no problem, I'll post eveything, and all the info you could possible need
Old 03-17-2013, 01:28 PM   #14
You just became my best friend. Now I just have to find the wife a car of her own (she cant drive a stick and pretty much refuses to learn, she said we have to get her a car before i can make mine a sticky lol)
---------- Post added at 01:28 PM ---------- Previous post was at 01:27 PM ----------
oh yea, and save up the money for it....and wait for parts.....but that's just details...lmao
LCMC Member
Old 03-17-2013, 01:38 PM   #15
Boomdizzle's Avatar
Pretty awesome man, seems like this will be a very helpful thread for some people!
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 03-17-2013, 11:25 PM   #16
GDogg08's Avatar
We'll the T5 is in!!!!
Been a long day, just need to put in pedals and clutch cable. The test drive!
My gf is so pissed I did this, she can't drive stick either, and she thinks she can't tell me what I can and can't do to my own car, I don't even let her drive it so wtf lol.
We'll she gon learn today, I do what I please
Old 03-17-2013, 11:37 PM   #17
lol, looking forward to hearing how it goes
LCMC Member
Old 03-17-2013, 11:52 PM   #18
GDogg08's Avatar
There were many times i sat there saying what did i just get myself in too, but as long you keep pushing yourself to continue, u will hit your goal. Wish i had a lift, but i got my car almost 4 feet off the ground, with old school jack stands that are very tall, and a modified bumper jack.
Old 03-18-2013, 08:07 AM   #19
Crowned1's Avatar
lmao can't wait to hear how it goes!
Old 03-18-2013, 08:34 AM   #20
GDogg08's Avatar
im hoping the pedal assemble isnt as hard as everyone says
Old 03-18-2013, 09:35 AM   #21
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Good luck and sounds like you've made good progress!
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 03-18-2013, 09:39 AM   #22
GDogg08's Avatar
Thanks!
Old 03-18-2013, 11:44 AM   #23
SpeedyG's Avatar
Goodluck and send lixs
SpeedyG is offline   Reply With Quote
Old 03-18-2013, 11:48 AM   #24
Boomdizzle's Avatar
Sounds like you need a new girlfriend.
haha, JK.
But that's very impressive you were able to do that without a lift. I barely was able to do the exhaust without a lift, I can't imagine doing a transmission swap!
Old 03-18-2013, 12:39 PM   #25
GDogg08's Avatar
haha, JK.
No your right, i do!!!
But i been with her for 7 years since my Jr year in high school. I need a way out lol
Yeah it was crazy at times, but somehow worked!
Old 03-19-2013, 04:21 PM   #26
GDogg08's Avatar
weird setback, the throwout bearing fork doesnt seem right. Not much tension with it, like when i push the clutch pedal down, it wont come back up on its own.
Its like there is suppose to be a spring on the clutch cable to push the fork back toward the back of the car. I have no idea about this issue. Its literately the only thing i have left till i fire her up.
Anyone have an idea?
Old 03-19-2013, 11:25 PM   #27
GDogg08's Avatar
Ok well i figured it out, my gf's grandpa wasnt paying attention and put the throwout bearing in backwards, instead of it being towards the clutch it was going back towards the trans. Had to pull the trans out a foot and swapped it around. Minor setback, took an hour to fix it!
Now shes almost done!
just the seat and center counsel and its done
Old 03-20-2013, 06:08 AM   #28
2Greeny7's Avatar
Nice! Good find! Good luck I hope everything else goes well!
2001 V6
11:42 PM
