Accel vs MSD coil pack - Mustang Evolution
Old 03-11-2013, 09:11 AM   #1
austinknoll's Avatar
Which would you choose, I can't decide which One is better. Price wise the MSD is cheaper but which one puts out more power?
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 03-11-2013, 04:25 PM   #2
Dgerow12's Avatar
MSD. More renowned name. Better reviews. Heard lots of horror stories about the accel coils
Dgerow12 is offline   Reply With Quote
Old 03-11-2013, 04:36 PM   #3
PonyBoyV6's Avatar
MSD really woke up my v6. They make a good product.
PonyBoyV6 is offline   Reply With Quote
Old 03-11-2013, 07:09 PM   #4
If you've heard bad things about a more expensive and doesn't state how many volts it puts out. MSD it is then.
65 Mustang coupe
Old 03-12-2013, 03:05 PM   #5
I have an MSD, and had it on my car for a little while. I put the stock one back on because I decided it wasn't worth the trouble once I found out it would probably last about a year. I've thought about putting it back on, has anyone had one that hasn't crapped out? Does it actually make a difference? I can't tell with all the other mods I have on my car if it made a difference or not.
Redstang19 is offline   Reply With Quote
Old 03-12-2013, 09:56 PM   #6
1slosix's Avatar
to be honest a coil pack really won't do anything upgrade wise...if you felt anything from putting one on it's because your oem was wasn't working the way it should anyways. as far as brand either MSD or and OEM Motorcraft would do fine. i tend to stay away from Accel in all that i do at work...
carving corners like a boss
Old 03-13-2013, 12:02 AM   #7
sam62893's Avatar
Sorry to ask a different question, but you only really have to replace a coil pack once it takes a dump right? And to replace plugs and wires you would recommend the OEM motorcraft ones as well? Because I've been told I have a misfire would replacing all that help?
Old 03-13-2013, 01:51 AM   #8
I don't see how a greater spark could do nothing for a motor
65 Mustang coupe
Old 03-13-2013, 07:49 AM   #9
The only thing I can see greater spark doing is using up your spark plugs faster.
Old 03-13-2013, 09:45 AM   #10
1slosix's Avatar
pretty much..over time though our coils do get weaker which is why i say that when people say they notice a difference it's normally due to that
Old 03-13-2013, 11:06 AM   #11
So why would you choose oem over MSD?
65 Mustang coupe
Old 03-13-2013, 01:03 PM   #12
1slosix's Avatar
Quality... My factory coil is at 9 years and running great.
Old 03-13-2013, 01:07 PM   #13
Lets put it like this, a coil either works or it does not work, if it works you don't need a new one. If it works then why put an aftermarket one on that is supposed to add more power to the spark but once your ECU rewrites it will give out the same spark your stock coil did.
Old 03-13-2013, 05:03 PM   #14
sam62893's Avatar
Some things are just better OEM. Why spend more on name brands if it does the same thing
08:28 PM
