Headlights - Mustang Evolution
Old 03-11-2013, 12:10 PM   #1
greenstang41's Avatar
Headlights
My low beam light won't come on
But my high beam do
Does anyone know whats wrong
greenstang41 is offline   Reply With Quote
Old 03-11-2013, 12:48 PM   #2
Blizzard's Avatar
It could be a loose wire, check the plugs around your hid kit
Blizzard is offline   Reply With Quote
Old 03-11-2013, 01:04 PM   #3
I have looked at all the wires and disconnected and reconnected and they won't come back on
Old 03-11-2013, 05:50 PM   #4
Can anyone help
Old 03-11-2013, 06:53 PM   #5
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
Happened to me, check drivers side plug where the three wires plug into the factory turn on connectors.... That's what happened to me, I had to fix the wires around a few times and then it works....
Hope this helps!!!
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 03-11-2013, 07:22 PM   #6
Xaperez100's Avatar
Is your brights the HID's? Or just brighter lights because I have HID's and my lows use my normal lights only one of my normal lights turn on. Because my normal lights broken inside
Xaperez100 is offline   Reply With Quote
Old 03-11-2013, 08:02 PM   #7
My low beam is hid
And I checked the connector wires and they still won't come on
Old 03-11-2013, 08:31 PM   #8
2Greeny7's Avatar
Originally Posted by greenstang41
My low beam is hid
That's odd..... I don't really know what else to trouble shoot...... Your positive the brown, blue, white is correct???
---------- Post added at 12:31 AM ---------- Previous post was at 12:31 AM ----------
That combo tells the bulb when to be off, low, and high, so you could have mixed two of them up
2001 V6
Old 03-11-2013, 09:08 PM   #9
Xaperez100's Avatar
Originally Posted by greenstang41 View Post
My low beam is hid
It's probably a bulb
Old 03-12-2013, 10:40 PM   #10
1slosix's Avatar
he isn't using the older halogen lo / hid high bulbs...he is using a 100% hid bulb.
op do you just run lo's or do you have a hi/lo kit. if it's just a lo kit swap your ballasts with each other...if the issue follows then you know it's a faulty ballast. if it's a hi/lo kit the ground is normally the biggest issue. does the bulb shift properly when changing from hi to lo or lo to hi? (that's if it's a hi/lo of course)
carving corners like a boss
Old 03-12-2013, 10:42 PM   #11
I have lo beam hid and the ballast was broken
So I got a new one and they still don't come on
Old 03-12-2013, 10:45 PM   #12
1slosix's Avatar
did you just swap the ballast or the bulbs as well...they are kinda fragile. If you wanna test with new bulbs hit up amazon. i only use ddm ballasts but the bulbs i get from there lol...you can pick up a pair for about $6
Old 03-12-2013, 11:10 PM   #13
I swapped both
Ballast and bulb
Old 03-12-2013, 11:11 PM   #14
Old 03-12-2013, 11:29 PM   #15
1slosix's Avatar
Have you checked if the harness is even getting fire?
11:28 AM
