cam questions - Mustang Evolution
Old 03-12-2013, 10:43 PM   #1
lemons95's Avatar
cam questions
most cams at SSM need 1.7 rockers. Where do I get those. I want to get the lumpycam. I might have to get the low-lift lumpycam if I can't find the 1.7 rockers.(the ones at SSM are roller rockers and there 1.7 but there $495 I can't afford that right now)
they have the stronger springs at comp cams(are dual spring's good or should I get beehive?)
to sum it up, I need some cheap-ish(maybe budgets a better word) 1.7 rockers, and some strong valve springs.
Old 03-13-2013, 12:21 AM   #2
davidcseifert's Avatar
Region: Arkansas
That $495 includes everything you need to use the roller rockers, aside from the pushrods.. Comp pro magnum rollers, the studs they ride on, the guide plates, and the locks for them
So basically you either save more or use stock rockers
If you do get them order the pushrods from comp, they're less than $100 whereas SSM charges $125
None are cheaper than the comp rockers, Harland sharp makes some but $$$$
Technically you don't need the rockers, that's just what SSM uses to give you specs off of for lift.. The factory pedestal mounts are 1.73 ratio, and are fine as long as you don't have stupid amounts of lift/duration
As for springs, LS springs are cheap and will support up to .570 lift, all you need for them are the gt spring retainers to get the proper install height and you can reuse your locks for the stems
blower/new cam soon
Old 03-13-2013, 08:32 PM   #3
lemons95's Avatar
Could I use SSM's lumpy cam with the stock rockers? the specs for it are duration 218/226 and .50 lift or is that a stupid amount of lift and duration?
and where can I get the LS springs and gt spring retainers.
Old 03-13-2013, 09:43 PM   #4
Region: Arkansas
No that's a baby cam lol I have the same one just different lsa
Find some stock LS1/LS6 springs and then 99-04 gt retainers, probably summitracing/jegs, Tousely ford parts depot has the retainers really cheap
blower/new cam soon
Old 03-13-2013, 09:55 PM   #5
Torchredfrankie's Avatar
What if I want a cam just for sound? Something that will give me that nice chopping sound with out replacing anything else?
Torchredfrankie is offline   Reply With Quote
Old 03-13-2013, 09:59 PM   #6
2300turboford's Avatar
Thumper cams are pretty much made for sound but u will see a gain in power
Old 03-13-2013, 10:59 PM   #7
We're can I get this?
Old 03-13-2013, 11:05 PM   #8
lemons95's Avatar
I'm pretty sure thumpr cams are only for V8's.
The lumpy cam sounds pretty good though.
» Members Mustangs
none
okfoz
Laura
2008Shelby
Add your Mustang
03:49 AM
