Exhaust manifolds - Mustang Evolution
Old 03-13-2013, 12:38 AM   #1
sam62893's Avatar
Exhaust manifolds
I have a pair of '97 exhaust manifolds I know they won't bolt up directly to the rest of the exhaust if I put them on an 02 motor but I can work that out. But how will I do the extra tubing on the drivers side manifold? And the O2 sensor I think on the passengers side. Will I just have to weld that shut or something?
Old 03-13-2013, 05:05 AM   #2
Project Pony's Avatar
You can have an exhaust shop weld it, or buy some o2 bung plugs from late model restoration for 15 bucks.
[SIGPIC][/SIGPIC]
Old 03-13-2013, 07:44 AM   #3
I've actually seen 99-04's with those manifolds on them, I think you could swap them in just fine and they should flow better than the stock 99-04 manifolds because those ones you got off your 97 are actually headers. Unless you have changed your exhaust then you might run into a problem?
Redstang19 is offline   Reply With Quote
Old 03-13-2013, 10:10 AM   #4
Venomouz831's Avatar
I was going to say the same thing. I believe people have ran these on the 99-04 sixers
)02 Gt, Founder of WE2G
Old 03-13-2013, 10:21 AM   #5
sam62893's Avatar
I think I'll get them welded to be better assured that I won't encounter problems in the future. I am actually putting them on an '02 motor that is going into a '97 shell. I got pretty much the complete exhaust from the '02 and I will be using the muffler and tailpipe from the '97 so everything should bolt on fine. I might have to bend some pipes a bit
Old 03-13-2013, 11:04 AM   #6
1slosix's Avatar
Youll have to widen the midpipes collectors i believe since they are 1/4" smaller on 99-04 but besides that i dont see an issue...ive been planning on doing this swap myself.
carving corners like a boss
Old 03-13-2013, 11:52 AM   #7
sam62893's Avatar
I'll try and bolt everything on outside the car see if it fits. How would I widen them. I saw this tool at autozone to widen your tailpipe, would that work? The midpipe collectors are the ones that go after the manifold right? Where the cats go?
Old 03-13-2013, 01:02 PM   #8
1slosix's Avatar
maybe take some sn95 collectors and weld to your NE midpipe to make the fitment easier
Old 03-13-2013, 05:01 PM   #9
sam62893's Avatar
mid ninety's b6 and well dam well damn to your mid mid ninety's b6 and well damn to your mid pipe.
Sorry, but lamens terms please? I'm not too familiar with exhaust terminology
Old 03-13-2013, 05:30 PM   #10
1slosix's Avatar
lol my autocorrect ruined that whole post...what i meant to say was you may find it easier to just take the collectors from an sn95 and weld them to the NE midpipe you have
Old 03-13-2013, 06:54 PM   #11
sam62893's Avatar
Oh man, I thought I was going crazy lol okay well the sn95 manifold is a bit bigger in the collector than the stock one but I'm pretty sure if you tighten the bolts enough there would be no problem right? I also took a second look at both sn95 and NE manifolds and I think I can put dummy o2 sensors in there and no buggy. Also the tubing on the passenger side manifold is different but you can exchange them for each other. For future reference. You will need WD40, a big a$$ wrench, and lots of endurance. Maybe a friend to help you out cause that thing was STUCK on there but I managed to get it off.
Sorry, the ME app doesn't let me put pictures throughout the text so they're all at the bottom so you can see what I'm talking about
ID:	95827   Click image for larger version
ID:	95830   Click image for larger version
ID:	95832   Click image for larger version
ID:	95834   Click image for larger version
Old 03-13-2013, 07:33 PM   #12
sam62893's Avatar
Another problem I ran into. The manifold doesn't couple with the NE exhaust. Should I cut the couplings off and exchange them or how would this go down?
Old 03-13-2013, 08:07 PM   #13
sam62893's Avatar
I used my sources (and brain) and used the "search feature. I searched exhaust manifold and found an old thread about manifolds cracking. Another member said to make the holes bigger on the exhaust and it'll be good. I guess I can try that. Nothing like a little bit of trail and error for the learning process
Old 03-14-2013, 10:32 PM   #14
Ghostedmind's Avatar
I was planning on doing this exact mod when my manifolds cracked, i still have the manifolds off the 94-99, You are exactly right 1slosix, they bolt straight up to the block (believe me i know because i had them bolted up to the block before i found out...) however, the flange on the collector is larger than the flange on the rest of my exhaust, so you would need to cut your exhaust right behind the flange, put one on that would fit and weld it back together. from what i could see there was no way i was going to be able to elongate the holes enought to fit it.
Like i said, lol, i have the manifolds in my house. Just sitting waiting for me to have the money to do it. just waiting it out to see if the other side cracks, and if they do the ones i have are going on there.
LCMC Member
Old 03-14-2013, 11:31 PM   #15
sam62893's Avatar
Yeah, I have the headers bolted on to the motor too. But the problem that persists is bolting them on to the collectors. I'm trying a circular file/ drill combo to maybe widen the holes on the collectors enough to fit the bolts on. I feel sorry for you man. When my manifold cracked it was the drivers side and that was pretty hard to take off. I can imagine taking the passenger one off with the egr and everything. Luckily I'm working on the motor outside of my car so everything is on hand and super easy to work on
Old 03-14-2013, 11:41 PM   #16
1slosix's Avatar
remember the sn95 collectors are 1/4" wider then the NE collectors...
Old 03-14-2013, 11:56 PM   #17
sam62893's Avatar
So it would be easier to cut the collectors from both exhausts and weld the sn95 to the NE along with the bolt fasteners or whatever they're called? I'll get some quotes from some exhaust shops. I don't have a welder at my disposal
Old 03-14-2013, 11:58 PM   #18
1slosix's Avatar
yeah it'd make it easier
Old 03-15-2013, 12:07 AM   #19
sam62893's Avatar
Got it. I'll try it out tomorrow and I'll post pictures if I get it up for future reference if anyone else would want to try it
exhaust
03:20 PM
