Tran Oil change - Mustang Evolution
Old 03-13-2013, 03:49 PM   #1
Torchredfrankie's Avatar
Tran Oil change
5 speed transmission oil going to change it to royal purple what wight do I use? Or were can I get it with out ordering it online?
Torchredfrankie is offline   Reply With Quote
Old 03-13-2013, 03:55 PM   #2
v8pony's Avatar
Do you have the Tremec 3650? If so don't use royal purple, it's advised against by tremec themselves, bad for syncros I believe.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 03-13-2013, 08:31 PM   #3
1slosix's Avatar
use oem fluid and swap a qrt for some penzoil syncromesh...your syncros will thank you in the long run
carving corners like a boss
Old 03-13-2013, 09:36 PM   #4
So no royal purple? ):
Old 03-13-2013, 09:45 PM   #5
http://www.americanmuscle.com/royal-....html#readMore
Will this be good???
Old 03-14-2013, 01:19 AM   #6
Venomouz831's Avatar
My mechanic friend also said to use oem ford oil. I asked why and he said that the weight in it is different and when cold it's thicker and harder to shift. My friend used it on his 350z (royal purple) and had to flush it out after a month because he said it was a pain to shift.
)02 Gt, Founder of WE2G
Old 03-14-2013, 05:45 AM   #7
1slosix's Avatar
I just don't wee why you'd need RP...oem does a great job for less. Just don't forget the mesh
Old 03-14-2013, 08:07 AM   #8
I wouldn't use Royal Purble in a stock transmission, if the transmission was built up, short shifter, aftermarket clutch and so on. It could be used, but stock just stick with what's in there.
Redstang19 is offline   Reply With Quote
12:40 AM
