4.2 rebuild - Mustang Evolution
Old 03-16-2013, 09:17 PM   #1
ProjectTurboV6's Avatar
4.2 rebuild
Just got the 2002 4.2 today and I'm curious on how to prepare it for a turbo. I wanna get the ssx stage 3 power package with ported heads, upper/lower intakes and a stage 3 cam... But will that coincide with a turbo setup?? Also what sized fuel rail/ injectors would be ideal for a 15-20lb of boost setup?
ProjectTurboV6 is offline   Reply With Quote
Old 03-16-2013, 09:30 PM   #2
I would imagine so... Heads and intake is only porting and polishing and the cam just look in the website and figure out what cam fits your build
Blackedout is offline   Reply With Quote
Old 03-16-2013, 09:32 PM   #3
Ghostedmind's Avatar
The ported uppers and lowers and heads will be fine, and if you look on their website they have a chart that suggests what to get. Also, if you call them you can tell them what you want to do with it and what you want the cam to do and the will grind you a custom one.
LCMC Member
Old 03-16-2013, 09:40 PM   #4
Man I wanna cam
---------- Post added at 10:39 PM ---------- Previous post was at 10:38 PM ----------
All what's left of my build is what ever stage three heads they have, rocker arms, cam and either turbo or pro charger
---------- Post added at 10:40 PM ---------- Previous post was at 10:39 PM ----------
Post some pictures of the block man
Old 03-26-2013, 04:44 AM   #5
Would forged internals really add up to 40hp and 40tq???
Old 03-26-2013, 04:56 PM   #6
Your gonna need forged internals if you plan to run 15-20 psi
dhuskers_11 is offline   Reply With Quote
Old 03-27-2013, 03:27 PM   #7
you will also want a lower compression with that amount of boost, unless you plan to run higher octane that 93
Just a Six
v6procharged is offline   Reply With Quote
Old 03-27-2013, 03:52 PM   #8
I'd say no higher than 9, maybe 9.5
LCMC Member
Old 03-27-2013, 04:28 PM   #9
i run stock compression in mine, 9.2
Just a Six
Old 03-27-2013, 09:47 PM   #10
I would run 8.7
01:52 AM
