Misfire or something else? - Mustang Evolution
Old 03-17-2013, 12:03 AM   #1
My latest pony is a 2002 Convertible with a V6 automatic. I have only had it about a month. I have noticed that when the engine is cold, it starts fine, but when I shift into drive or reverse, the engine seems to misfire, or at least it feels and sounds that way. If I hold the brake it will do that for several minutes then go away. If I drive off it seems to run fine and go away quickly. Any guesses as to the cause out there?
mustanglvr1959 is offline   Reply With Quote
Old 03-17-2013, 12:05 AM   #2
1slosix's Avatar
have you done any of the basic cleaning things on it? MAF, IAC, fuel filter, TB, air filter
carving corners like a boss
Old 03-17-2013, 12:14 AM   #3
No. Although it was serviced by the dealer. What should I look at specifically?
Old 03-17-2013, 12:27 AM   #4
1slosix's Avatar
the things i listed then..the dealer doesn't bother with any of them
Old 03-17-2013, 12:38 AM   #5
Will do....thanks for the input.
Old 03-17-2013, 11:16 AM   #6
By the way - i am familiar with MAF, but what does IAC and TB stand for?
Old 03-17-2013, 11:18 AM   #7
Idle air control and throttle body
Blackedout is offline   Reply With Quote
Old 03-17-2013, 11:31 AM   #8
Ghostedmind's Avatar
does It sound like the same kind of issue me and the guy who started this thread have?
LCMC Member
Old 03-17-2013, 11:53 AM   #9
sam62893's Avatar
Mine seems to have the same problem. I've cleaned the MAF and IAC. But I have yet to clean the throttle body. Will do that today and see what happens
Old 03-17-2013, 12:06 PM   #10
well, like I said in that thread, I've got 3 days off coming up and I'm going to try cleaning out the EGR ports and see if that helps.
LCMC Member
Old 04-05-2013, 05:40 PM   #11
UPDATE:
I'm not sure if it has completely gotten rid of it but if it hasn't it has damn sure smoothed it out. I wasn't able to completely clean it but what little bit I was able to do with taking the upper intake Manifold off and some carb cleaner has helped tremendously
LCMC Member
Old 04-06-2013, 09:17 AM   #12
You probably need new spark plugs, I've seen this happen before when plugs get real old the gaps can close up and when you start your engine it runs real bad for a while until it warms up, that is the gaps opening back up again. Check your plugs and see.
Redstang19 is offline   Reply With Quote
Old 04-06-2013, 11:53 AM   #13
its not the plugs, heres another post about this.
Shake at idle only
that tells you what all i've done trying to remedy this issue. Add to that this past "weekend" i cleand the IAC and the EGR ports in the lower intake, and I have come to the conclusion that I am going to delete my EGR and my PCV hoses so i rid myself of the exhaust gases and the oil through the intake
LCMC Member
12:20 AM
