grinding and popping sharp turns - Mustang Evolution
Old 03-17-2013, 06:12 PM   #1
I got all new suspension and an alignment. Something feels like a grind popping when I steer real hard sometimes feels like something's gonna give out
Blackedout is offline   Reply With Quote
Old 03-17-2013, 06:15 PM   #2
Ghostedmind's Avatar
how far (if any) did it lower? it sounds like its hitting your fenders, steering linkages etc. Best thing to do would be to park it, turn the wheel as hard as you can one way then get under there with a flashlight and see if you can tell if it is rubbing anything, and do that for turning each way.
LCMC Member
Old 03-17-2013, 06:16 PM   #3
I had a grinding problem a few months ago turned out to be my lower ball joints. Changed those and haven't heard it since.
Redstang19 is offline   Reply With Quote
Old 03-17-2013, 06:23 PM   #4
H and r springs, steeda ballpoints, steeda bumpsteers, caster chambers, shocks and struts
---------- Post added at 07:23 PM ---------- Previous post was at 07:19 PM ----------
Lowered 1.75 front and 1.6 rear with an added half inch in the front lowered and no spacers just isolator a with the springs bc the springs came with aluminum spacers I didn't put them on
Old 03-17-2013, 08:05 PM   #5
Siendly22's Avatar
Did you put grease on the steeda balljoint before you install it? It happens to me when I forgot to grease it after installation. Try that for a while. Hope it helps
Siendly22 is offline   Reply With Quote
Old 03-17-2013, 08:13 PM   #6
Yeah I put grease in there but the rubber boot came off bc the metal ring came loose
Old 03-17-2013, 08:28 PM   #7
Siendly22's Avatar
How long you have it in your car the x2 ? Here's mine after a month installed and forget to grease it , ball joint is shot already !
Old 03-17-2013, 08:31 PM   #8
They been on for a year
Old 03-17-2013, 08:32 PM   #9
Siendly22's Avatar
It's popping when you turn the steering wheel?
Old 03-17-2013, 08:33 PM   #10
Never greased them since I but them on
Old 03-17-2013, 08:36 PM   #11
Siendly22's Avatar
I think your ball joint is shot man! You can till return that, call steeda
---------- Post added at 07:36 PM ---------- Previous post was at 07:35 PM ----------
You have to grease the steeda balljoint after you install it
10:01 PM
