Mach1 apperance package - Mustang Evolution
Old 03-17-2013, 08:16 PM   #1
Burkeys96GT's Avatar
I just got my mach1 pack from am and was wondering where everyone runs the chin spoiler and what looks better either flush with wheel wells so flush this front of the bumper
Burkeys96GT is offline   Reply With Quote
Old 03-17-2013, 08:23 PM   #2
Lorraine's driver
ab_mach1's Avatar
The stock Mach 1 position is where it's just in toward the engine from being flush. This is between 1/8" to 1/4" from being flush to the front. They sell one that installs flush to the wheel wells. I guess it depends what you like. Do you know which one is included in your kit?
Instagram: @ab_mach1
Old 03-17-2013, 08:34 PM   #3
1slosix's Avatar
i've run both...i like the non flush up front
carving corners like a boss
Old 03-17-2013, 08:37 PM   #4
QTY Item Name Price 1 99902 - Mach 1 Grille Delete & Chin Spoiler Kit (99-04 GT, V6; 99-01 Cobra) $109.99
That's the kit I got I'm not sure on the chin spoiler they sent if its the one your talking about
Old 03-17-2013, 08:39 PM   #5
The actual factory OEM chin spoiler is made out of a much higher quality material, and will fit the best.
Most kits or chin spoilers that are for sale for under $100 are the glossy plastic that can be mounted flush at the front of the bumper, but will not sit flush with the fender wells.
As said the true Mach 1 positioning is to have the chin spoiler sit back 1/8-1/4" under the bumper. I positioned mine ~1/4" back and it looks great. I originally tried to have it sit flush under the bumper and the ends were about 1/2" to an inch short to the fender wells.
Old 03-17-2013, 08:40 PM   #6
1slosix's Avatar
that's why i use the chin from LMR...oem matte black and sits how it should. granted i painted mine lol
Old 03-17-2013, 09:05 PM   #7
I was going to get that one too but I figured after I lowered mine 2" in the front it'd catch hell, so the cheaper spoiler was the better option. I actually like the glossy look over the matte finish too...really adds to the black n blue scheme when she's all polished up with meguiars.
Old 03-17-2013, 11:17 PM   #8
MACh237's Avatar
Send a message via MSN to MACh237 Send a message via Skype™ to MACh237
Yup that`s the one i`m running look perfect, can`t be OEM quality and style
- 2004 Ford Mustang V6 (Summer Ride)
- 2000 Volkswagen Jetta (Winter Beater)
- 2011 Hyundai Accent (Last Resort)
- 2012 Aldo Beel Leather Shoes (Daily Ride)
MACh237 is offline   Reply With Quote
Old 03-18-2013, 10:49 AM   #9
SpeedyG's Avatar
I am about to order the same appearance kit. Question???? Do you drill your own holes or is there a certain way to install?
SpeedyG is offline   Reply With Quote
Old 03-18-2013, 01:14 PM   #10
Project Pony's Avatar
Agreed. Stick to the true mach 1 setup with it recessed about 1/4". I tried mine both ways as well and I personally think it looks goofy when it is flush with the front.
---------- Post added at 03:14 PM ---------- Previous post was at 03:14 PM ----------
You drill your own holes. Measure twice, drill once! Take your time.
[SIGPIC][/SIGPIC]
Old 03-18-2013, 04:58 PM   #11
Yes you do have to drill holes but don't be intimidated by it. As said get your spoiler line up exactly where you want it. I used plenty of duct tape to hold it in place as well as an extra set of hands and then I drilled.
Me and my buddy did both our cars in about 45 min...longest part was getting it lined up the way we wanted on the bumper.
Old 03-19-2013, 03:09 PM   #12
It came in is the pony supposed to come with hardware
Old 03-19-2013, 03:21 PM   #13
Lorraine's driver
ab_mach1's Avatar
It probably came with plastic push-pin sorta things. You drill the holes and push the pins thingy's in through the spoiler into the hole.
Attachment 97029
Attachment 97030
^kinda likes these
Old 03-19-2013, 03:30 PM   #14
It came with pin for the chin spoiler but no screws for the pony in the grill
Old 03-19-2013, 03:59 PM   #15
Ghostedmind's Avatar
it should fit in with pins/screws that are holding up your old grill/bumper
LCMC Member
Old 03-19-2013, 05:01 PM   #16
Attachment 97023
The grille delete plastic panel uses the existing push pins that the stock corral uses. The floating pony should come with a couple screws...if not just pick some up at a hardware store..pretty basic like 1/4x20 or 3/16.
The chin spoilers used to come with nuts, bolts and washers. I believe they come with push pins or something similar now. I personally would buy some nuts and bolts for the chin spoiler...they'll hold up much better.
There'd be nothing worse than driving down the road and you suddenly feel a thump under the car and you find out it was your chin spoiler
Old 03-19-2013, 05:06 PM   #17
I'd like to do put the mach 1 shaker hood system on my car, I'd rather use the mach 1 hood though over the kit you can get for it. Plus I wouldn't want to cut a big hole out of my stock hood lol.
Redstang19 is offline   Reply With Quote
Old 03-19-2013, 05:38 PM   #18
I got the grille installed it was simple and I didn't break the plastic flaps in the bottom of the grille delete
Old 03-19-2013, 06:23 PM   #19
Lorraine's driver
ab_mach1's Avatar
Looks good! Especially with it being a white stang.
Old 03-20-2013, 08:27 PM   #20
The shaker's cool but not $750 cool imo lol. Plus unless you do some custom fabbing to the shaker unit you'd have to use a stock 99-02/99-04 GT hood and cut the hole. The shaker on the v6 doesn't sit in the same location as on the Machs so the stock Mach 1 hood will not work without fabbing to get the intake to line up properly.
To do all that seems like an aweful lot of time/money for a weak ram intake...mainly all show.
Old 03-21-2013, 06:15 AM   #21
Got the chin spoiler installed last night it was simple with basic hand tools even the 1/4 in drill bit was spun by my fingers because my drill died but she's in and looks amazing
Old 03-21-2013, 07:16 AM   #22
Lorraine's driver
ab_mach1's Avatar
It looks great. Great dedication to your Mustang when your drill died. Lol
Old 03-21-2013, 04:47 PM   #23
Attachment 97309
Attachment 97310
Attachment 97311
Man chin spoilers and grille deletes look so good on white stangs.
Get some smoked headlights to complete that front end.
Old 03-21-2013, 07:55 PM   #24
04SilverSixer's Avatar
Did you have to jack it up to install?
04SilverSixer is offline   Reply With Quote
Old 03-22-2013, 01:40 PM   #25
Nope where she sits In the pic is where I did it at
Old 03-22-2013, 04:04 PM   #26
sam62893's Avatar
Unless your car is lowered 2 inches I don't think you'll need too. Even then I think that's enough space
Old 03-22-2013, 04:47 PM   #27
tonyd01gt's Avatar
Mach 1 apperance package
I'd like to do put the Mach 1 shaker hood system on my car, I'd rather use the Mach 1 hood though over the kit you can get for it. Plus I wouldn't want to cut a big hole out of my stock hood lol.
I have the kit on my car. IMO i don't think it is that bad looking.Kit was fairly easy to install. And came with everything needed. I love the look of the shaker. Give my car a real muscle car look. The OEM Mach 1 hoods are hard to find. And expensive on top of that. Plus there are difference in where the intake /shaker sit on the Mach 1, and other mustangs, if i am not mistaken.My kit was a lot cheaper than getting the OEM parts. And, it is mostly cosmetic. The chin spoiler came out great. Good job.
Name:	2001 Ford Mustang GT #1 001.JPG
ID:	97841   Click image for larger version
tonyd01gt is offline   Reply With Quote
Old 03-23-2013, 03:19 PM   #28
Yeah that does look pretty good, I'd love to find a Mach 1 in general but I think my V6 would look good with that too. Although I could use that money on something else too, so it's a win lose situation I guess.
Old 03-23-2013, 03:34 PM   #29
tonyd01gt's Avatar
Mach 1 appearance package
Hey, it's all about your personal taste. I want my car to look like a mustang. But Not look like everybody else mustang.
Old 03-23-2013, 05:13 PM   #30
That's a good way to look at it.
09:45 PM
