Taking off Cats - Mustang Evolution
Old 03-18-2013, 09:37 AM   #1
Mustang10's Avatar
Taking off Cats
Would the check engine light turn on if I take out the two back Cats since the sensors are connected to the two front ones? I've heard it and its louder and the persons check engine light didn't go on?
Mustang10 is offline   Reply With Quote
Old 03-18-2013, 09:41 AM   #2
Crowned1's Avatar
Yes it does go on if the O2 sensors are removed. There is a couple of ways to go about this, you can drill holes in the piping to fit the sensors and then weld them on. Also there is another method having to do with MIL eliminators, but I'm not familiar with that so maybe someone can chime in.
Crowned1 is offline   Reply With Quote
Old 03-18-2013, 09:45 AM   #3
Lorraine's driver
ab_mach1's Avatar
Most probably it will come on. It may not be immediately. But, you can get MIL elliminators that you plug in that will turn the check eng light off. If you have a tuner, you can also make it so the tuner turns the check eng light off too.
Plug-in MIL Eliminators (96-04 All)
Instagram: @ab_mach1
Old 03-18-2013, 10:04 AM   #4
Mustang10's Avatar
The sensors are on the front two cats
The guy that showed me took off the back two cats with no sensors that's why his check engine light didn't turn on.
Old 03-18-2013, 10:21 AM   #5
Dantheman94's Avatar
I was thinking about doing this as well and from my knowledge, the back cats don't effect the oxygen sensors at all. All they do is measure how well the front cats work so it shouldn't cause an engine light if u get rid of them. Although I think I'm going to switch for some high flow cats
Dantheman94 is offline   Reply With Quote
Old 03-18-2013, 10:38 AM   #6
SpeedyG's Avatar
Yes the light goes in and the exhaust sounds gets LOUD! But not a good loud a very raspy nasty loud, not mustang like. I know in some states you can get away without cats but not mine.
SpeedyG is offline   Reply With Quote
Old 03-18-2013, 10:55 AM   #7
jdavis96gt's Avatar
Region: West Virgina
Shouldn't throw check engine light since you'll still have your front cats.
Old 03-18-2013, 11:36 AM   #8
Mustang936's Avatar
I have a 2000 gt with the back two cats removed, its been 3 months and no CEL
Mustang936 is offline   Reply With Quote
10:10 PM
