need help to reconnect pdfe!!!! - Mustang Evolution
Old 03-23-2013, 07:22 PM   #1
siulnagap's Avatar
Question need help to reconnect pdfe!!!!
Hello!!!
I have a 2001 mustang v6 automatic
recently, the check engine light turns on, I went to autozone so they could check what was the problem, it said it was the EGR valve thing which I replaced.
The check engine light didnt turn off, I disconnect the battery a whole day so the computer could reset completely, but it came on again after a while.
I checked the connections at the egr zone and I notice that the pdfe tubes where disconnected (you know, the 2 little rubber tubes that are stick to the sensor area)
The thing is that I cant find where they are supposed to go, I have checked everywhere I can but still not find the place where they go, Im clueless.
I know that this must be the reason why it still giving me the EGR failure code when they check it.
Please, does somebody knows where those things are supposed to be connected?
and if you have any pics so I can use as a reference would be great
thanks!
siulnagap is offline   Reply With Quote
Old 03-23-2013, 11:33 PM   #2
1slosix's Avatar
not off the top of my head but i'll pop my hood tomorrow and see if i can find it for u
carving corners like a boss
Old 03-23-2013, 11:48 PM   #3
siulnagap's Avatar
Thanks !
I will take a pic later on to post it so you can see
Old 03-24-2013, 07:31 AM   #4
sam62893's Avatar
I got an 02 engine an tranny sitting out in my backyard. I can take pi tires up down under and around without obstruction. I'll try once there's light outside lol
Old 03-24-2013, 09:02 AM   #5
siulnagap's Avatar
Ok! Lol
Old 03-24-2013, 09:58 AM   #6
sam62893's Avatar
And I kinda sorta.... Locked my keys under my hood.... Hahah
ID:	98025   Click image for larger version
ID:	98027   Click image for larger version
ID:	98029   Click image for larger version
ID:	98031   Click image for larger version
ID:	98033   Click image for larger version
ID:	98035   Click image for larger version
Old 03-24-2013, 10:22 AM   #7
siulnagap's Avatar
Yes! Is the one that you can see on pic 2, 5 and 7, but theres something funny,
I cant see the pipe thingies that comes out from the Big egr pipe, there just not there. I bough the car a month ago, maybe the previous took them out?
Old 03-24-2013, 10:24 AM   #8
sam62893's Avatar
Do you have pictures?
Old 03-24-2013, 10:29 AM   #9
siulnagap's Avatar
No, I will take some when I arrive home, Im working
Old 03-24-2013, 10:35 AM   #10
sam62893's Avatar
Alright just post them up when you get a chance and then we'll come up with possibilities or solutions
Old 03-24-2013, 10:38 AM   #11
siulnagap's Avatar
Ok, thanks!
Old 03-24-2013, 10:41 AM   #12
sam62893's Avatar
That's what we're here for
Old 03-24-2013, 10:57 AM   #13
sam62893's Avatar
Sorry double post
Old 03-24-2013, 03:37 PM   #14
siulnagap's Avatar
Here are the pictures of the headache area!!!! lol
ID:	98108   Click image for larger version
ID:	98110   Click image for larger version
ID:	98112   Click image for larger version
ID:	98114   Click image for larger version
ID:	98116   Click image for larger version
Old 03-24-2013, 03:56 PM   #15
Ghostedmind's Avatar
your EGR tube just doesn't have the DPFE sensor tubing....
LCMC Member
Old 03-24-2013, 04:00 PM   #16
sam62893's Avatar
Oh wow. How long has the CEL been on and how long have you had the car? You've never messed with the egr tube or the exhaust manifold right? Other than someone replacing the egr tube I don't know how that could have happened. Your best fix would be to snag an egr tube off a wrecked mustang and replace yours (make sure it has the little spouts in it lol)
ID:	98127   Click image for larger version
Old 03-24-2013, 04:05 PM   #17
siulnagap's Avatar
Hi, thanks for letting me know, I was suspecting that too, so I will need to reinstall one, but where does the dpfe sensor tubing goes connected too?
Old 03-24-2013, 04:12 PM   #18
sam62893's Avatar
You mean the sensor with the rubber tubes? It basically lets air flow through the sensor and back to the egr. And the sensor is connected directly to the wire harness.
It starts;
Exhaust manifold
Egr tubing
Egr tubing sensor
Then egr itself
Old 03-24-2013, 04:13 PM   #19
siulnagap's Avatar
The cel has been on like for 3 weeks already, I bough the car early march, I didnt know about that fact of the dpfe thing till I checked why that thing was loose and where its supposed to be connected.
I found out while checking videos on how to connect the pdfe, I noticed it goes connected to a kind of tubing it supposed to have but for a reason mine doesnt hsve it, so to the yunkyard with me or to ebay! Lol
---------- Post added at 04:13 PM ---------- Previous post was at 04:12 PM ----------
Old 03-24-2013, 04:32 PM   #20
siulnagap's Avatar
So apparently the previous owner replaced the egr tube with the wrong one then
Or is that tube another one appart?
The tube it has doesnt even have a sign it had those connections for the pdfe rubber tubes
Old 03-24-2013, 04:33 PM   #21
sam62893's Avatar
Probably replaced it with a '94-'98 tube. Those don't have the sensor. But yeah your best bet would be the junkyard. It's an way fix but a pain to take it off due to limited space
Old 03-24-2013, 04:38 PM   #22
siulnagap's Avatar
I will check then at the yunkyard and I will need to pass by that painful experience! Lol
Old 03-24-2013, 04:42 PM   #23
i guess not all mustangs have that sensor though, i know mine doesnt have it
LCMC Member
Old 03-24-2013, 04:53 PM   #24
sam62893's Avatar
I know the sn95 doesn't. I think the '99 doesn't either I don't know about the '04 though. They always change things the years before and after they change platforms.
But yeah man, good luck
» Members Mustangs
My baby
Cinn
Airika
dwood63
Add your Mustang
04:02 PM
