Here's my newest issue - Mustang Evolution
Old 03-23-2013, 07:41 PM   #1
Ghostedmind's Avatar
It usually only does this when its cold outside and I start it up the first time of the day, right after I stopped the video it went away, I'm thinking its coming from the water pump, or one of the pulleys, I'm pretty sure its not the belt. Just looking for a second opinion really
LCMC Member
Old 03-24-2013, 03:17 PM   #2
Someone could have told me it wouldn't let you watch the video. Its fixed now.....
LCMC Member
Old 03-24-2013, 03:18 PM   #3
Venomouz831's Avatar
I know you said it's not coming from the belt but I had the same sound on my 02 and I cleaned the belt and the sound went away.
)02 Gt, Founder of WE2G
Old 03-24-2013, 03:30 PM   #4
what did you clean the belt with?
LCMC Member
Old 03-24-2013, 03:34 PM   #5
Ubnbit's Avatar
I was watching and as soon as I thought, dang I wish he would rev it a little, it was right on Q. I'm not sure though exactly which pulley it's coming from. If I had known the video wasnt working, I would have told you. It'd be nice if you had some lithium grease. Hit each pulley with it until it stopped. Then if you did them all and it didn't stop, move on to maybe your water pump.
Old 03-24-2013, 03:40 PM   #6
that was the idea i had when it first started, i didnt have lithium grease but i did have WD-40, and like i told the wife if when i hit it with the WD-40 it stopped i was going to head out and get some lithium grease to put on there, but it never helped. which is why i moved on to my water pump, but my car still stays in the normal range so the pump itself is not bad, just sounds like its not lubricated...i really hope Venomouz is right and its the belt, spend $20 for a new one and done, heck even if its the idler or tensioner pulley thats 15-20 and done, i'd hate to have to change the water pump.... (well, really my wife would, because i'd take that time to do a drain and flush, change the thermostat and clean out my intake manifolds, which is more money that she wants to spend ofc, lol)
---------- Post added at 04:40 PM ---------- Previous post was at 04:40 PM ----------
oh, and there's no weeping around the water pump at all
LCMC Member
Old 03-24-2013, 03:44 PM   #7
Ubnbit's Avatar
That was my next question about the weep hole. Id definitely start with the belt then. You have already covered the basics. Are all of your fans off when it does it? No heat on or anything?
Old 03-24-2013, 03:59 PM   #8
this was the first time i started the car for the day, we were headed out and it started doing it and i was like ($*** gotta get a video of this real quick) the ac was still on from the day before and the fans weren't on, engine was still cold. like i said it stopped right after i stopped recording and didn't start up again
LCMC Member
Old 03-24-2013, 04:01 PM   #9
Ubnbit's Avatar
Ohhhh. If it does it again, go straight to the ac and turn it off. See if it goes away immediately.
Old 03-24-2013, 04:03 PM   #10
Alright, I'll try that too
LCMC Member
Old 03-24-2013, 04:07 PM   #11
Ubnbit's Avatar
Could be the compressor. I could be wrong and hope I am. Not a mechanic, just try to so things myself.
---------- Post added at 06:07 PM ---------- Previous post was at 06:07 PM ----------
Beautiful car tho.
Old 03-24-2013, 04:42 PM   #12
someone on youtube said Cam syncro
LCMC Member
Old 03-24-2013, 06:54 PM   #13
Dgerow12's Avatar
Cam synchronizer is what it sounds like to me
Dgerow12 is offline   Reply With Quote
Old 03-24-2013, 07:27 PM   #14
Has anyone on here changed their cam synchronizer ? how difficult is it and is there anything I should really pay attention to?
LCMC Member
Old 03-26-2013, 05:43 PM   #15
Tried the AC thing, no change so its not the compressor, the belt looks a bit shiny on the flat surface so i'm going to buy a new one on payday and see if that takes care of it, and while i have it off i'm going to check the pulleys as well.
LCMC Member
Old 03-26-2013, 05:46 PM   #16
Ubnbit's Avatar
Hopefully that'll be it. Be about the cheapest thin to try. Keep us posted.
Old 03-26-2013, 06:03 PM   #17
i hope so too, and will do
LCMC Member
04:53 AM
