Which one.....???? - Mustang Evolution
Old 11-20-2003, 09:33 PM   #1
Send a message via AIM to v6white98
Which one.....????
Which one would be better to get first
ported upper and lower intake...
ported headers...
or a new cam...
i dont have the money to get them all
right now so i was wondering which one would
be best to get first???
Eventually yes i will get them all, but thats later on down
the road
-Matt
v6white98 is offline   Reply With Quote
Old 11-20-2003, 10:39 PM   #2
Monkey's Avatar
if you have the money for one now, and HAVE to spend it, i would get the intakes. it is easiest to do heads and cam at the same time. so i would save for heads and cam so you could do them now. but then again, you have to take the intakes off to take the heads off. so if you go for it, i would do it all at the same time.
Old 11-20-2003, 11:09 PM   #3
Rick0636's Avatar
Good thinking, save on your labor, or the money you spend on it, mechanics won't work cheap usually.
Old 11-21-2003, 03:28 AM   #4
RGR
Send a message via AIM to RGR
Cam I say. You can get a set of those lifter pullers (12) and
remove the cam without pulling the lower intake Cam alone
is probably the biggest boost in HP for the V6. For sure on the split
ports, which have good flowing heads & intakes stock.
Just an idea.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
06:24 AM
