Stock exhaust - Mustang Evolution
Old 03-25-2013, 04:00 PM   #1
98mustang11's Avatar
Stock exhaust
Prolly been asked but I can't find it and didn't see it in the exhaust sticky... Will the exhaust of a 94-98 gt bolt up to my 98
98mustang11 is offline   Reply With Quote
Old 03-25-2013, 04:30 PM   #2
Robbiemustang96's Avatar
Assuming you have a V6 you will need a mid pipe that goes from the Y to H pipe. In other words yes lol the mid pipe you have now has the two headers which go like this \/ which is the v part of the Y and then the bottom part of the Y is your stock exhaust. Dual exhaust is a H mid pipe. Srry its so confusing
Robbiemustang96 is offline   Reply With Quote
Old 03-25-2013, 04:43 PM   #3
Yea that confused me lol I was going to have an h-pipe fabbed up anyways so I didn't have to buy one... I just figure I bolt that exhaust up an get the mufflers switched for the ones I bought it would be way less cheaper
Old 03-25-2013, 04:54 PM   #4
Yea if you can fab them yourself or have someone do it that would save you some cash
Old 03-25-2013, 05:43 PM   #5
1slosix's Avatar
you can run the cat back from fox bodies, sn95's, and new edges without issue once the midpipe is made up
carving corners like a boss
Old 03-25-2013, 05:46 PM   #6
The top is a v6 the bottom is a gt... Could you not just unbolt it from the very back off the header and bolt it up to a v6?
Old 03-25-2013, 05:48 PM   #7
Thats what i was trying to say lol. If you can find a GT.
Old 03-25-2013, 05:57 PM   #8
1slosix's Avatar
no...the collectors are different along with the actual bends off the manifolds
Old 03-25-2013, 05:58 PM   #9
Lol yea I got the exhaust priced at like 275 to 300 how much you think that would drop it?
Old 03-25-2013, 05:59 PM   #10
1slosix's Avatar
that price for what exactly?
Old 03-25-2013, 06:00 PM   #11
You go ahead and take over here so i dont give false info lol
Old 03-25-2013, 06:05 PM   #12
The whole exhaust iv got the mufflers and iv got the tips they just have to run new pipe and weld it
Old 03-25-2013, 06:11 PM   #13
1slosix's Avatar
still a bit high if you're supplying all that but if that's the best you can do in your location go for it...if you can however get the tail pipes from a GT that'll make things cheaper in the long run
Old 03-25-2013, 06:13 PM   #14
That I can do guy wants I think 30 for them
Old 03-25-2013, 06:21 PM   #15
1slosix's Avatar
if they are in good shape buy them that should save quite a bit of labor charges since they won't have to bend the over axles..which are generally the most expensive part of our exhausts
Old 03-25-2013, 06:48 PM   #16
That's what I figured but the guy went up to 75 on them
---------- Post added at 07:48 PM ---------- Previous post was at 07:47 PM ----------
But I could just go to a junk yard and cut the exhaust pipes off couldn't I? If she I just need to cut from behind the muffler back right?
Old 03-25-2013, 08:31 PM   #17
1slosix's Avatar
yep..on a stock GT you'll be able to unbolt the tail pipes from the mufflers so no need to cut unless the bolts are rusted...then i'd just cut the bolts first to keep as much pip as possible
exhaust
03:57 PM
