1 and 2 on shifter - Mustang Evolution
Old 03-25-2013, 07:59 PM   #1
greenstang41's Avatar
1 and 2 on shifter
What are the 1 and 2 on the shifter for
greenstang41 is offline   Reply With Quote
Old 03-25-2013, 08:04 PM   #2
Billymich's Avatar
Selecting gear 1 and 2?
Old 03-25-2013, 08:08 PM   #3
Robbiemustang96's Avatar
So you can drive it like a stick 1, 2 then drive
Robbiemustang96 is offline   Reply With Quote
Old 03-25-2013, 08:11 PM   #4
SpeedyG's Avatar
In a way, yes. They are meant for when you need more low gear power such as uphills.
SpeedyG is offline   Reply With Quote
Old 03-25-2013, 08:19 PM   #5
Or getting out of snow
Old 03-25-2013, 10:42 PM   #6
SpeedyG's Avatar
+1
Old 03-26-2013, 01:28 PM   #7
Billymich's Avatar
Or plowing through a crowd of people.
Old 03-26-2013, 04:11 PM   #8
Crowned1's Avatar
1,2,D,OD*
Crowned1 is offline   Reply With Quote
Old 03-26-2013, 04:54 PM   #9
XD
Redstang19 is offline   Reply With Quote
Old 03-26-2013, 10:36 PM   #10
Torchredfrankie's Avatar
Don't try to drive it like its stick your only going to kill your tranny. Trust me I know I did it with my 98
Torchredfrankie is offline   Reply With Quote
Old 03-26-2013, 10:41 PM   #11
Ghostedmind's Avatar
good excuse to get a new one though XD
LCMC Member
Old 03-26-2013, 10:46 PM   #12
Venomouz831's Avatar
Yea if you constantly do it
)02 Gt, Founder of WE2G
Old 03-27-2013, 05:17 PM   #13
Yes just leave it in D
If you want your auto to shift better and more aggressively, look into a jmod or shift kit, and/or custom tunes and a handheld tuner.
If those mods still don't do it, consider the 3rd pedal mod
Old 03-27-2013, 05:38 PM   #14
This is probably my next mod
LCMC Member
Old 03-27-2013, 06:31 PM   #15
SpeedyG's Avatar
Third pedal???
Old 03-27-2013, 06:34 PM   #16
Auto to stick shift swap
LCMC Member
Old 03-27-2013, 06:35 PM   #17
Ubnbit's Avatar
1 and 2 gears are exactly that. Your car won't shift out of that gear until you manually shift it. If you go down to 1, you will literally go 10 at 6000 rpms. Don't pull down into these gears at high speeds or car go boom lol.
Old 03-27-2013, 08:17 PM   #18
BloodRedStang's Avatar
A harder shift is actually better for a auto trans because automatics, when the shift, are technically in 2 gears at once so to speak which is why shifts are usually smooth with an auto.
That said, with a factory shift tune, and components, some things will take more of a beating shifting manually. Plus shifting manually with a stock auto is pretty useless, multiple second delay between shifting the lever and actual shift.
Look into an older hydraulic AOD with a forward manual valve body and a ratchet shifter.. hell of a lot of fun and the shifts are hardd lol only downside is with a manual valve body vs a shift kit is you have to manually select gears, no put it in D and go.. lol
BloodRedStang is offline   Reply With Quote
04:52 AM
