Plasti Dipped Car Fail:( - Mustang Evolution
Old 03-26-2013, 06:45 PM   #1
BlackSmoke02's Avatar
I would seriously appreciate any type of help I could get. I bought a spray gun from Home Depot and about 7 14oz cans and well when I first sprayed it it came out like little string like. Anf on top of it not coming out right, the dip would come outt white or grey when it should've come out flat black. I tried my hest to tweak it and adjust it but I just couldnt get it to how it suppose to be. I was wondering is it because of the gun that I jeed to thin the dip cause its too thick or what? I would really appreciate any type of advice or fixes to this please. Here are some pictures the best I got it was to about charcoal grey but the texture was weird kind of like fiberglass
ID:	98627   Click image for larger version
BlackSmoke02 is offline   Reply With Quote
Old 03-26-2013, 07:10 PM   #2
These are some more pictures there little better
ID:	98629   Click image for larger version
ID:	98631   Click image for larger version
ID:	98633   Click image for larger version
Old 03-26-2013, 07:22 PM   #3
What type of plasti dip did you buy?
Old 03-26-2013, 07:23 PM   #4
Black8thElement's Avatar
Your not goin to get a real gun from Home Depot, order one from dipyourcar.com if you want a good spray gun. I did my wheels a while back but I feel to do your whole car it's best to do it in closed quarters. With the wind blowing and sunlight doesn't let the plasti dry properly
Black8thElement is offline   Reply With Quote
Old 03-26-2013, 07:26 PM   #5
Rosco's Avatar
Did you do this outside? It looks like really bad overspray. If your painting outdoors and in an uncontrolled space do it early in the morning before the wind picks up. If there is wind the paint job won't come out good.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 03-26-2013, 07:30 PM   #6
Rosco's Avatar
I used this makeshift booth with the sides wrapped in plastic to make a paint booth. Idk on a whole car, perhaps 2 easy ups. It kept the wind out and spray nice, but be careful of temps getting to hot if you choose to do so.
Old 03-26-2013, 07:34 PM   #7
I bought black 14oz cans the ones with the peel back lid
---------- Post added at 05:34 PM ---------- Previous post was at 05:31 PM ----------
Well it was just coming out of the gun really weird. It was like little hairs shooting out and it wouldnt come out smooth and tried adjusting it and wouldn't fix
It was completely windless this morning when I did it. It wasnt hot either so that cant he it
Old 03-26-2013, 07:38 PM   #8
You bought the wrong stuff, you want to get the ones in the spray cans. What you got is un-thinned plasti dip, it is meant for literally dipping something into it for a rubber coating, not spraying. Sorry but you just watsted your money on that. You need the ones in the spray can. Or the gallon ones from DYC that come pre-thinned.
Old 03-26-2013, 07:58 PM   #9
Can't I buy some kind of thinner or reducer so its smoother and will come out the gun better when i mix them?
Old 03-26-2013, 08:08 PM   #10
You can but it still doesn't work as good as the pre-thinned ones. DYC even did a video and compared the prethinned and the other after they thinned it and it still looked like crap.
Old 03-26-2013, 08:28 PM   #11
Theres some guy named Venemouz I believe and he dipped his car exactly same way with same stuff as I did but his came out perfect
Old 03-26-2013, 09:12 PM   #12
goodwinta1's Avatar
Xylene as a 50/50 mix with the dip will work perfect.
goodwinta1 is offline   Reply With Quote
Old 03-26-2013, 09:25 PM   #13
I bought sone reducer just right now from Autozone it has acetone and some two other types of it. Is the thinner the problem of why it comes out like hairs?
Old 03-26-2013, 09:30 PM   #14
goodwinta1's Avatar
I really don't understand the physics of why it works. Just that the xylene does. I imagine that it has something to do with the acetone
Old 03-26-2013, 09:40 PM   #15
I hope the reducer I bought works better than todays spray. Would the tip size of the gun also be a factor of why it turned out like that?
Old 03-26-2013, 09:43 PM   #16
goodwinta1's Avatar
It honestly sounds more like the consistency of the dip. Try it out on an old piece of plywood before shooting it on the car. Make sure the tip is completely clean too.
Old 03-26-2013, 10:21 PM   #17
Alright tomorrow morning I'll do a mix and spray and see if it comes out correctly
And you said a 50/50 mix? Because the reducer says 1/4 but thats for paint
Old 03-26-2013, 11:27 PM   #18
goodwinta1's Avatar
The 50/50 was for the Xylene. If the reducer says 1/4 then start there. Test spray on something like plywood or whatever is laying around. You can always increase the amount of reducer if necessary.
Old 03-27-2013, 10:18 AM   #19
SpeedyG's Avatar
What Does dipping mean?
SpeedyG is offline   Reply With Quote
Old 03-27-2013, 10:20 AM   #20
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
It's the term used when you spray plasti dip on a part.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 03-27-2013, 05:38 PM   #21
goodwinta1's Avatar
How did the spray go this morning?
Old 03-27-2013, 06:06 PM   #22
It actually did smoothen up a bit but it still looks cloth like. Some parts it shoots grey amd some parts charcoal grey and rarely black. I used 1/3 of reducer. I did about 3 coats all around and now im just trying to see if I could get it black or dark grey so I could do a quick layer all around so it gets at least a nice color
Old 03-27-2013, 06:31 PM   #23
98mustang11's Avatar
Just use the spray cans... That's what I'm doin now piece by piece
98mustang11 is offline   Reply With Quote
Old 03-28-2013, 12:50 AM   #24
I sprayed some clear spray can dip and it turned blck instantly! I have no idea why or how but I just gave it shot since clear was lying around to see wgat would happen and it turned it black. Im gonna use up the rest of gun spray to give it good thick coats and by 2 or 3 clear cans to give it top layer of black.
Old 03-28-2013, 10:02 AM   #25
goodwinta1's Avatar
Sounds good man. Glad its working out.
06:28 AM
