01 v6 rear end - Mustang Evolution
Old 03-27-2013, 11:09 AM   #1
Rees's Avatar
01 v6 rear end
Is the rear end in a 01 a 7.5 or a 8.8? And will it fit into a 89 mustang?
Rees is offline   Reply With Quote
Old 03-27-2013, 11:38 AM   #2
01 V6 has a 7.5, i'm not too sure if it will fit in an 89 though. Maybe someone else knows.
Old 03-27-2013, 12:14 PM   #3
Rees's Avatar
Ok thank you.
Old 03-27-2013, 04:51 PM   #4
Yeah it will fit an 89, but if it's a 5.0 then I would put an 8.8 in.
Redstang19 is offline   Reply With Quote
Old 03-27-2013, 04:56 PM   #5
Gears:
- 94-98 v6's had the 7.5" rearend with 2.73 gears.
- 99-04 v6's also had the 7.5" rear but with 3.27 gears
Axles:
- 1994-1998 Mustang rear axles are 3/4" wider on each side than a 79-93 Mustang.
- 1999 and newer Mustang rear axles are about 1 7/16" wider on each side than a 79-93 Mustang.
- 94 and newer Mustang 8.8 will bolt into a 79-93 Mustang but will require brake line adapters.
- Lincoln Mark7 LSC, SVO Mustang and Fox Body Saleens use a rear axle that is 1.25" wider per side than the 87-93 Mustangs.
- 94-95 spindles share the same track width as 79-93 spindles.
- 96 and up spindles have an 8mm wider track width.
- 79-93 Mustangs all use 9" drums with 7.5 and 8.8 rear axles.
12:19 PM
